Question about Whirlpool MH7135XE Microwave Oven
Whirlpool Microwave Model MH7130XEZ-2
We have a Whirlpool above stove microwave model number MH7130XEZ-2. It lights up, clock works, the tray inside will turn, but for some reason it will not heat. What might this problem be and can I fix this, and how do I do it? Thanks!
  • Terry Dee Oct 14, 2007
    Thanks for your consideration ... and help!
  • Genaro Hernandez
    Genaro Hernandez Feb 21, 2008
    Have a Whirlpool model no. CFMT148G1W2 under the counter unit. All seems fine, including the noise made by the magnetron, but no heat is generated.
    Door switches, connections, etc check out OK. I read somewhere that a diode may be responsible for the failure. Could someone please explain how this diode can cause the unit to perform? Also, how can I test a bad diode using a digital multimeter that only has Voltage and resistance? Is it possible, or do I need a different multimeter?
    Thanks in advance.
  • Whirlpool Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa:
Posted on Oct 22, 2007
Where is the reset button on a whirlpool microwave #MH7130XEZ-2
Hello Art. If you want to reset your Microwave, we would recommend resetting it by shutting it off from the circuit breaker for at least a minute.
May 08, 2017 | Whirlpool Microwave Ovens
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
Model MH7130xez won't heat. everything else works. the clock, timer and lights. does this model have a fuse?
if unit won't heat, then there is a problem with either the magnetron or the diode. if its the magnetron, the microwave will sound almost normal. if its the diode, it will make a humming sound
Mar 26, 2011 | Whirlpool MH7135XE Microwave Oven
Whirlpool microwave model #MH1140XMQ-1. I needed to change the light bulb on the bottom of the microwave that shines on the stove below. I started to turn the light bulb and the bulb seperated from the...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or if you prefer, you can order a new control circuit board for it here for $140.10 plus shipping. (Just enter the model number as MH1140XMQ-1 without the dash).
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
Jul 04, 2009 | Whirlpool MH7140XF Microwave Oven
Our Danby DMW162-ORT doesn't heat up food. The digital numbers, inside light, clock and turning tray are all working.The fan is working but no heat. It's also making a whining/grinding sound that wasn't...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Jun 15, 2009 | Microwave Ovens
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
The door part# is 4359542 if you need the part number. If you need to know how to replace the door check up by the upper hinge on the inside of the door should be a plastic piece that you can remove so if you lift the door off of its hinges. You may or may not need to remove the grill above the door to raise the door high enough
Oct 31, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
481 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
