Question about Maytag PAV2300 Top Load Washer
MAYTAG top loader makes high pitched squeal when agitating/spinni
My MAYTAG top loader makes a high pitched contstant whine/squeal while agitating and spinning. Can someone please tell me what is wrong? I tried to remove the agitator to check things out, but failed, because I could not figure out how to do it. My washer is about 6 years old, model number SAV2655AWW
    President:
  • 1,489 Answers
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
My Roper top load washer is making a squealing sound.. Is it a belt?
Most are belt drive on front loaders and on some top loaders but not all. Other culprit can be a dry bearing. Get into it a take a look. A length of plastic hose makes a good stethoscope to pinpoint the noise.
Oct 02, 2016 | Roper Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
2006 AUDI A4 2.0 HAS A HIGH PITCH SQUEAL AT IDLE TAPERS OFF AT HIGHER RPM -THEN MAKES A WHINING NOISE WHEN ENGINE IS SHUT OFF --ANY IDEAS?
hey not sure if its totally right but the high pitch squeal at when its idleing could be the tentioner pulley bearings on the engine belt not sure about the whining noise when its shut off
Oct 04, 2009 | 2006 Audi A4
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
Jan 22, 2007 | Maytag Legacy Top Load Washer
Maytag PAV2300 Top Load Washer Logo
830 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
