Question about Canon ImageRUNNER 330s Copier
I have a canon imagerunner 330s copy machine. I'm
I have a canon imagerunner 330s copy machine. I'm getting uneven horizontal lines across my paper. It would seem that a roller needs cleaning, but I have run the roller cleaning option several times and it doesn't seem to do anything. Have you got any suggestions?
    President:
  • Canon Master
  • 990 Answers
Hello sir;As your descript, it seems need to replace drum blade, if they come with whole cartridge then replace whole cartridge.
Posted on May 12, 2009
Obstructed copy
Typically when labels come off the paper, the get stuck on the Fuser (the heating rollers just as the paper exits the machine) Open up the printer and turn the round hand that you would clear a jam with, and look on the roller to see if they are stuck there.
They are also known to get stuck in the paper tray or pickup assembly. Follow the paper path through the machine and you will find them.
Good Luck
Jun 03, 2012 | Canon ImageRUNNER 330s Copier
I have a canon 4570 imagerunner,the problem i am facing is when i am printing a copy 2(sometimes 3) horizontal lines appears on the print.please sugest. Thank You
If the lines repeat in a regular fashion, with a consistent distance from each other, you need to replace the imaging drum. I would take a print out with the horizontal lines on it, then fold the paper up until two of the lines overlap each other; this will tell you the general diameter of the drum and give you an idea of what to look for inside the machine.
-David.
Nov 03, 2010 | Canon imageRUNNER 4570 Copier
The copier copies but the paper stays in the machine
sounds like to me the fixing assempbly needs to be worked on. there could be a broken drive gear in the fixing assembly that is not turning the fuser rollers properly and is causing the copier to jam
May 27, 2010 | Canon ImageRUNNER 330s Copier
Uneven copy quality- Canon Copier
If the toner isnt burned on paper it means that you have to change fixing roller bushings and fixing roller.
Because you have uneven pressure between fixing and press roller
May 27, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon Imagerunner 330S toner replacement
Unlike most toners, this one snaps on the top and the toner is transfered into a holding tank so you don't actually remove anything from the machine.
Jan 07, 2010 | Canon ImageRUNNER 330s Copier
Imagerunner 330s id
remove all the ids you stored in the machine. even one id is left means it will ask for p/w.
Feb 18, 2009 | Canon ImageRUNNER 330s Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
Canon imagerunner 3300 line on page
if you are using the feeder then there is something on the thin glass and it needs to be cleaned. if you are using the platen glass and the line is still there then you need a new drum.
Oct 29, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
214 people viewed this question
old marine
old marine
