Question about Northern Tool Optics
Binoculars barrels won't stay in position, need tightening tool
Cabela's XT full-sized binoculars: the two halves do not stay in position when adjusted for eye-width. I think the problem is a screw-like part in the bridge,under a plastic, screw-in part with the serial number. This part, which has two holes on the outer, upper suface probably needs tightening. The problem I have is that a special tool to fit in the two holes is needed to turn the part. I can't turn it by inserting a small screw-driver into one of the holes. Where can I find the part to adjust the tension on the bridge mechanism that holds the two barrels of the binoculars in place?
Thank you.
Dan
  • 26 Answers
Try needle nose pliers
Posted on Jun 22, 2009
How to hold binoculars properly
1. Remove the lens covers, if they are in place.
2. Set the diopter on the right barrel eyepiece. The function of this setting is to adjust between vision differences between your eyes if you are NOT wearing corrective lenses. Set to zero if you do have corrective lenses on (glasses or contacts). For proper diopter adjustment see this article: Binocular Selection Guide.
3. Most binoculars will hinge in the middle to allow for differences in the spacing between the eyes. Set the spacing to fit your eyes.
4. Adjust eye cups. Each eyepiece will have a means of maintaining the correct eye relief for the user. On quality binoculars the rim of the eyepiece will extend and retract as you twist the eyepiece rim. Move all the way in if you are wearing eyeglasses or adjust out if not wearing eyeglasses. You will know if they are set correctly when you look through the binoculars and check to be sure that the circular edge of the view should be sharp and not fuzzy. At this point we are not looking at any object in the view but rather the perimeter of the view. You may need to adjust the eye cups again to compensate. On lower cost binoculars the eyecup may only be a rubber lip that you either fold over (the "in" position) or out.
5 Raise binoculars to your eyes and use one finger to adjust the focus wheel on the center shaft between the two barrels, until the view is in sharp focus. If viewing for extended periods you may want to keep your elbows down near your side as this will increase comfort while viewing.
Final safety tip: Do not look at the sun through binoculars.
Many people enjoy observing nature with binoculars. Having them handy is key. Hunting, astronomy, marine use, and stadium sports are a few more activities where having a pair of binoculars can make a real impact to your experience.
Mar 06, 2014 | Zeiss Optics
Focusing problems
Hello Samaro,
This effect is produced when the tho sides of the binoculars are not focusing the same.
Since you sayit is present at long distance, it might be that one barrel is stuck and is not focusing the same as the otherone when you scroll the middle "focuser".
What you can do is open it up and try to clean it, also see if there is something, that is making one of the lenses not move forward as far as the other one.
Good luck,
Dahaka
Jul 28, 2008 | Fujinon CD Binocular
I have Minolta Pocket 8x24/8.7, 40 year old binoculars. One side is "limp" and doesn't stay in position for viewing. Fix??
Most compact binoculars have a central bridge. The objective (big lens) end of the binocular hinge usually has a ball bearing in it. The other end may either have a blanking cap or a hub where the neck strap attaches. Removing this cap or hub will reveal a grub screw which tightens another ball bearing against the bridge. Take the appropriate part off the limp side and look for the grub screw. Tightening it will decrease the "limpness". Be careful, as these are sometimes set in place with a locktite of some kind. Best to release pressure first before tightening.
Jan 31, 2010 | Minolta Activa Pocket Binocular
I'm trying to figure out what kind/model of cabelas binoculars I have. they are very large, say bak-4 prisms, 20x80 field 2.7
these binoculars were made for astronomy or day viewing but are hard to hold steady by hand, best to use tripod...bak4 prisms means you should get a sharp image from edge to edge, in cheaper models with cheap prisms only the center of the field of view is sharp.......larry@reichinstruments.com
Jun 25, 2009 | Cabela's Astronomical (20x80) Binocular
How to focus my Zeiss 10x40B TP binoculars
Your binoculars are known as the Zeiss Classic or what was once known as the Dialyt. They focus differently from the usual binoculars like those mentioned. The rear wheel is to focus both binocular barrels while using them. The front focus wheel is adjust the right eyepiece to suit your right eye. Binocular manufacturers take into account each eye is slightly different. To focus the Dialyt...First close your right eye and turn the rear wheel until the image is sharp in the left barrel. Leave the focus wheel alone. Now close left eye and adjust the front wheel until the image is sharp for your right eye. The image should now be clear and in focus for both eyes. It should not be needed to use the front wheel from now on. The rear wheel is what you will use to change the focus from near to far objects.
May 31, 2009 | Zeiss Classic B/GA 524013 Binocular
8 X 30 eyepiece has come loose
Use strong glue and then put it on!
Feb 06, 2008 | Tasco Sonoma Binoculars
Cabelas Alaskan Guide 10X42
I agree with you on that! I have a feeling they are either Nikon or Leupold sourced. The body is alot like green ring leupold ive seen but the lenses have a magenta multicoating on a lens surface which ive seen on nikon. I'm in the process of looking for the maker of them myself as I need an objective lens. I'm going to call the Cabela's Cust SVC number and see what they say. I've heard the new Euro styled binoculars are made by Meopta.
Nov 25, 2007 | Cabela's Alaskan Guide Binoculars
LEITZ TRINOVID 10X22C BINOCULARS
Yes , but note that covers are glued so use a pin to  lift cover gently . The screw should be secured --when you are finished tightening-- with 'locktight' or touch of nail varnish.
Oct 28, 2007 | Carson Optical Tracker 8 x 21 mm Ruby Wide...
Optics Logo
394 people viewed this question
Top Northern Tool Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Northern Tool Optic Expert? Answer questions, earn points and help others
