Question about Dell 946 All-In-One InkJet Printer
Dell Printer 946 paper jam.
I have a sheet of Staples glossy photo paper jammed in my Dell 946 printer. I can grab a hold of the trailing edge but can't dislodge it. Is there a release mechanism I am not aware of or a release procedure?
    Sergeant:
  • 296 Answers
Hi
its a case of paper jam in ur printer,here are two sites recommended,kindly visit these sites thoroughly, i hope u will b able to ve an idea about how to release stuck paper from ur printer and all other necessary procedure and important information regardin ur respective query.
if u find this answer is satisfying ur need then plzz don forget to rate this.
all the best .
thankyou.
THe two sites recommended are:
http://www.ehow.com/how_113761_clear-printer-paper.html
http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
Posted on May 12, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper goes scew whiff when trying to print. Says there is a paper jam but none visible.
Smaller torn bits of paper may still be in the printer. Unplug the power, open the back access panel. Look for torn or jammed paper. Also check the ADF (auto document feeder) for a jam.
When you try it again, Dell recommends that you fan your paper. Fanning the paper helps break apart the bonds left by improperly cut paper which leaves the edges of the sheets interlocked.
Dec 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
My Dell 1720dn constantly has paper jams. A
I am having the same problem, did this get resolved?
Dec 02, 2009 | Dell 1720dn Laser Printer
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam
hmmm..I think there is a back door on that printer..try to open it on the back of the printer...
it will allow you to grab the jammed paper..^^
turn off the printer before grabbing the jammed paper..
May 07, 2009 | Dell 962 Photo All-In-One InkJet Printer
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
Paper is jamed
I have a HP697c and sometimes it grabs more than one sheet and gets jammed. I take hold of the trailing edge and pull hard and slowly till it comes back out. Then I remove and straighten the feed pile and try again.
Nov 07, 2008 | HP DeskJet 920c InkJet Printer
Printer Jam
Its probably stuck wrapped around the fuser.
It WAS glossy Laser paper and NOT glossy Inkjet paper wasn't it ??
Glossy Inkjet paper could cause a proplem like this, as inkjet paper just isnt made to stand the temperature of a fuser (the fuser cover reaches a temp of just under 180 Celcius) and it melts !!!
Dec 12, 2007 | Samsung CLP-510 Laser Printer
Dell 946 All-In-One InkJet Printer Logo
80 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
