Question about Craftsman Nailer Kit, Palm Air Driver
Paslode framing nailer when fired pin stays out wont retract
Fires one nail then firing pin stays out
  • Samuel Charles Spriggs May 11, 2010
    The heading on this posting is confusing -- I think you are asking about a nail gun. I would frist try lubricating the mechanism which houses the firing pin.
  • 79 Answers
Check the anvil guide for damage first (ie: burrs, nicks, etc.) Then go to the chamber for the return spring. That is where your problems are.
Posted on Jan 15, 2010
Paslode compact nail. the firing pin will not return
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 19, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode framing nailer will onley fire one time and wont return to fireing pos. fires first nail great . started this problem after cleaning
Did you remember to lube the upper cylinder, lg 0-ring and silicone the striking pin----sticking may prevent returning to firing position
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
The pin that fires the nail sticks and won't retract after firing. You can push it back in after it fires, but that is very time consuming. tried cleaning and oiling to no avail.
please go to paslode.com and take a look at the gun's schematic. you have one of two possible problems. check the compression on the pin's piston( it should have 2 metal rings) put the piston at the top of the chamber and let it go , if it drops by itself you may need new metal rings. the other fix is to replace your reed valve( it kinda looks like a comb with four fat teeth) sitting right under your muffler
Feb 10, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode (30 degrees) framing gun firing pin not retracting
The tool needs to be completely torn down, cleaned out, two orings inside need replaced, re-lubed and re-assembled. takes a technician about 1 hour to do it right. I believe either the orings or dirt is your problem. If blade doesn't return its probably the orings.
Feb 10, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Craftsman Nailer Kit, Palm Air Driver Logo
598 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
