Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
My french door with freezer at bottom ,LG icemaker making very little ice.
    Problem Solver:
  • 6 Answers
Perhaps there is not enough water coming into the tray on each cycle? Are the ice-cubes very thin? If so timer needs to be reset. LG use a 3-switch DIP on a control panel near the main power board. By changing these switches to various combinations of on/off you can change the timing - longer means more water each time (but too much water means overflow into the blocks already made).
There are service manuals that explain what each setting does - but because its near the high-voltage power board, I'd suggest you get a repairman unless you are a good DIY'er
Posted on Jun 10, 2009
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Make the icemaker make more ice ?
Keep open and close freezer door. There is switch to make it goes any faster. Make sure freezer setting is at least half way on the dial.
Sep 10, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Jun 09, 2009 | LG LFC25760 French Door Refrigerator
Motor noise and flashing light
The problem you may be having is an ice build up. Defrost the unit and take out the back wall of the freezer. Cut the insulation off as in the picture and it will solve the problem. What happens is a little bit of water gets trapped and then over time it becomes a massive ice ball that can block the fan. First you hear the ticking noise and then you get ER FF error.
Sgt 48
May 16, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker not making cubes
You may have ice built up in icemaker where the water goes into it.  You will have to remove the icemaker and to get the ice cleared out.  Once that's done, you should be ok.
Jan 13, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
264 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
