Question about Jenn-Air Electric Double Oven
Dimdisplay Model jjw9627aab
    Scholar:
  • 54 Answers
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Posted on Aug 13, 2009
Whirlpool double electric oven model D245. Buttons beep when pressed, oven lights up when door opened. Cost to repair control board?
that isn't a good model number,how old is this oven?if it's over 15 years you can't get parts for it most likely,when you find the model number off of the oven go here and see if you can still get parts for it.
https://www.searspartsdirect.com/model-number/GMC275PDB07/1198/0125400.html
Sep 27, 2017 | Whirlpool Ovens
Does anyone know what the part numbers are for the baking elements in the oven upper and lower, model is an LG LST5651sw
Here is the link to LG appliances LG RANGES OVENS Support
I entered the number you provided and it couldn't find a match; you might want to re-check the number, or look at a model close to yours.
Mar 24, 2015 | LG Ovens
Unable to find model number for electric oven
Hello, Smlmyers -
Look at the image for the location of the sticker with the oven model on this web page:
http://www.stockportrepairs.co.uk/Lamona/Oven
Scroll down the page. The image is near the bottom.
Best wishes from a volunteer answerer in the USA.
Jan 18, 2018 | Ovens
Kenmore serial number vf44745959
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. !!
Feb 20, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
I JUST BOUGHT A FLOOR KENMORE GAS RANGE THAT WAS A FLOOR MODEL AND THEY SAID THEY DO NOT GIVE THE MANUEL WITH IT. WHERE CAN I GET A MANUEL. IT IS A MODEL 70402 ITEM #0220402000. i BOUGHT IT AT THE SEARS IN...
You can order the paper manual from Sears by calling 1-800-252-1698. They will need the entire model number though. Here is info on where to find the model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=70402&pathTaken=partSearch
You can download the manual here:
http://www.kenmore.com:80/shc/s/nb_10154_12604_NB_CCownersmanuals?adCell=WF
Again, you will need the entire model number. It should be located under the lid or on the back of the unit. It will start with three numbers followed by a dot, then many more numbers, such as:
102.24300
If you have any further questions or problem locating model number, let me know and I can help further.
Aug 02, 2010 | Ovens
What model will relace my Stove Drop in Model
I will find out and contact you on Wednesday for this question. Ella
Aug 19, 2009 | Ovens
Jen Air double oven only beeps when you make any selection.
can you look real close at the display, its possibel that the display has "dimmed" and unit is actually working, but just cannot read the display as to what its actually doing, in this case replaccingthe display board will correct your problem
Mar 08, 2009 | Jenn-Air JJW8230D Electric Double Oven
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Nov 25, 2007 | GE JKP85 Electric Double Oven
Jenn-Air Electric Double Oven Logo
141 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
