Question about Motorola Mobility RAZR V3xx Cellular Phone
Keypad doesnt light up.i cant see the numbers at night or in the dark on the key pad
    Brigadier General:
  • 7,752 Answers
The flexcable need to be replaced to correct the light issue
Posted on Aug 18, 2008
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Thanx
Jul 26, 2010 | Nokia E71 Smartphone
I have a problem with my Nokia 6600 slide. The key pad light does not work. It makes no difference if it is light or dark. How do I turn it on?
open up your phone you'll need phone screw here.than you can check keypad connector,clean up with an pencils eraser(its safety) usually keypad or keypad light problem because off dirty connector.good luck.
May 21, 2010 | Nokia 6600 slide Cellular Phone
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Key Pad Light
Keypad light is turned on and off by sensing whether you are in light or in dark.
The phone turns off the keypad light when you are in sufficient light conditions.
Oct 29, 2008 | Nokia N72 Cellular Phone
Keypad light wont turn on
It is the problem of your ribbon flex that is connector..
If you have not a good hand you cant do it. Take it to a Motorola Repair Center.
I'm sure the phone will be full functional again.
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Keypad Problem
Have you tried it in the dark? There is a photo sensor that is located just above the right soft-key. It looks like a pin hole. Put your thumb over the hole and press a key on the keypad, you should see the keys light up. The purpose of this sensor is to prolong the battery life by not having to light up the keypad in the daylight.
There is a way to disable the photo sensor so that the keypad is on whether it is day or night. Look for a setting that allows you to turn the "battery saver" feature off.
- Jim
Feb 02, 2008 | Motorola Mobility RAZR V3
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Motorola Mobility RAZR V3xx Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
