Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Quick connect place screw is broken
Actually the female side of the screw is stripped and no longer able to keep the quick connect for the tripod attached.  Any way to fix this?
  • 72 Answers
Have it replaced.
Posted on Oct 20, 2007
How do I keep the button down when screwing the camera on
I suspect that this is the tiny locating button that sits beside the screw on the tripod.
Check your manual to find out how to remove the quick release sled. There is usually a small lever that needs to be rotated out of position and the sled lifts out.
Once you have the sled out, turn it over and you should see a small flap of metal that can be folded up and this is the means by which you screw the threaded part into your camera. Once it is tight, flip down the metal flap and then refit the sled to the tripod , taking care to rotate the lever again.
Some tripod levers remain locked while the sled is removed and they slip back into place when it is replaced in the tripod head.
Hope this helps.
Sep 17, 2014 | Sunpak PlatinumPlus 6000PG 61" Tripod
How to change lid switch in a Whirlpool top load washer.
Tools needed: Phillips screwdrive, flathead screwdriver, putty knife, 3/8 inch nut driver.<br /> <br /> Every model is different. So read though. While standing in front of washer there is a phillips screw on each side of console. Some models have a screw on each side but in back of console. Some models dont have screw so you will need a putty knife to slide under console on each side an push the clips inward and lift up on console. Once you have removed the screws or the clips lift the console and allow to flip upside down and the support hindges on the back of washer. Disconnect the quick connect the clips into another quick connect Brcketed on the frame. Remove the two gold curved shaped hinges one one each side with the flathead screwdriver.Tilt cabinet back and move it away from the washer. Unerneather you will see a quick connect with wires running to the lid switch. Remove the two phillips screws that are under the lid holding the lid switch in place. Remove the 3/8 inch nut holding the ground wire next to lid switch. There are also two hindges the hold the wires inside the lip of the frame. Pull hinges towards you enough to allow the wires to come out. Install new lid switch with the two phillips screws from the old one. Reconnect the 3/8 inch grounding wire to frame. Insert the wires back inbetween the hindges to hold wires. Snap the quick connect into the frame from underneathe. It can only go on one way. Once you have the new lid swtch installed than go back in front of washer. Place the cabinet back in place. Push the lower lip of the bottominside of cabinet back under lip of frame of washer. Gently tilt the cabinet back into place. Take your hand and make sure the glide (white plastic strips ) on the back frame line up and than put the gold hinges back in place. Than do the other side. Make sure its stable. Reconnect the lid switch quick connect. Place console back into place and make sure its snug. Put screws back in place. Now standing in front of washer. Tilt washer towards you to reset the self leveling legs. Now lift the lid and start your washer in spin cycle. Close the lid and open it until the basket returns to normal stopping mode. Keep doing this it usually takes 5-10 times increase speed of basket each time ( have lid closed longer for faster speeds). When the basket breaks are reset you will hear the breaks engage and the basket slowly comes to a stop. If you see it jerking or breaking hard The break package is not reset yet keep trying to reset. Once the break package is reset and the lid switch works good than its laundry time. <br /> <br /> Future knowledge: Lid switches go out for a few different reasons. If you drop the lid and it hits the lid switch hard it can start damaging it. Wear and tear using your washer will wear them out over time. Most common is the dropping of the lid which breaks lid switch over time. Thank you for taking your time to reason this How To and I hope this helped you in your task.
on Jul 28, 2011 | Washing Machines
My tripod is actually cx640 did not see it on the list, missing thing camera screws into.
Try this site:
Based on your Tripod CX-640 the quick release you need is Velbon QB-5LC. The website gives you pictures to verify.
Apr 11, 2011 | Velbon CX-690 Tripod
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
I cannot figure out how to get the plate off the head. I end up either putting camera on, then twisting the whole thing onto the tripod, or putting the head on the tripod and twisting the camera around to...
Sounds as if you haven't unlocked the quick disconnect plate from the 222 head.
Release the quick disconnect plate from the 222 pistol grip with the thumb release it will click open and pop the release plate up a bit to remove it. The affix this plate to the camera tripod socket 1/4 x20 female thread on the camera bottom. The underside of the quick release plate has a "D" ring to screw it to the camera, fold over the "D" ring and when you pit it back on the 222 set the edge under the lip and set it down the brass pin then will snap the thumb release over and lock into place.
See my diagrams
And the release plate
Jan 22, 2011 | Manfrotto 222 GripAction Ball Joystick...
How do i place the camera on the tripoid as it does not have a screw connection on top
The tripod comes with a quick shoe, which has a screw connection. The camera, with quick shoe attached, is then inserted into the slot in the pan head.
Oct 22, 2010 | Vanguard (TRACKER1) Tripod
Hi. The telescope itself became disattached from the tripod. How do I connect it again? There seems to be a screw, but it is not screwing in tight. THanks. Maria.
The female end may be stripped. You will need to re-tap the threads, and probably also buy a replacement bolt at any well stocked hardware store.
Aug 26, 2010 | Bausch and Lomb Discoverer 78-1600...
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at if you have questions.
Nov 07, 2008 | Photography
Cannot attach tripod plate to scope - stripped receptacle
Hardware stores should have thumb screws in different sizes and thread lengths ... box stores , local hardware ....
Jun 11, 2017 | Minox MD 62 ED W 62213
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
53 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
