I'm trying to separate the drum on a Hotpoint wf740, is this a sealed drum unit?
  • 483 Answers
Drum being seized in my opinion the bearings have seized to replace them you will need to remove the front of the machine disconnect all the wires from the drum not the machine there are two plastic pegs holding the suspension legs to the drum which you will need to remove. push the pins in at the backof the pegs and pull out the pegs,sorry you will need too remove the two concrete blocks top/bottom first, then remove the pegs lift out the drum remove the fixings around the drum with a t-30/t-40 bit,then split the drum now comes the tricky bit - AT THE BACK OF THE DRUM IS A 13MM BOLT UNDO THIS ONE TAKE OFF THE FLY WHEEL AND THEN REPLACE THE BOLT HIT THIS BOLT AS HARD AND AS CLEANLY AS YOU CAN WITH A LARGE HAMMER SO THE STAINLESS STEEL DRUM COMES OUT THEN YOU NEED TO GET THE OLD BEARINGS OUT THESE CAN BE A PIG SOMETIMES SO DONT GIVE UP THEN REPLACE WITH NEW ONE'S PUT BACK TOGETHER IN REVERSE ORDER.hope this helps if you can think you can do it it's not as bad as it looks ,good luck
Thanks
Fame !
Posted on May 13, 2009
Can the bearings in a hotpoint hv8b593g be renewed or is it a sealed drum
Don't know this precise machine but all I have worked on previously have not been sealed, the main outer drum normally comes out of the back after removing the drive belt and pully and unhooking from the suspension then separate the plastic outer drum from its two halves remove the inner drum and knock out the bearing, replace all in reverse order.
Aug 27, 2016 | Hotpoint Washing Machines
Is it possible to change the bearings on this model?
sealed units are separate to the tub and drum
I would first remove everything down to the outside drum as the noise could be from an obstruction ( coin/s bra wire, metal objects etc)
At 3 years I would not expect bearing trouble in a sealed unit so explore all other avenues of the noise first
bearings will be noisy at all cycles and not specifically at high speed spin
before you touch it -check the warranty period and if inside that period call the technician
Feb 10, 2016 | Hotpoint Washing Machines
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Door/drum seal has split causing a major leak also had probs for last few months where it gets to last 10 mins of cycle then it just counts down and doesnt complete the cycle it then gets stuck on 1 min...
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 18, 2009 | Hotpoint Aquarius WD640 Front Load...
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
