Question about Edimax PS-1203 Print Server
My notebook does not connect to printserver
I need some Help please.. i got the printsir plus 1203 printserver on my brother printer.. i used to use it in combination with an wireless router.. the printer has no usb -in so i have to use the server cause there i can go in by network cable.. no more wireless router.. when i connect notebook an printserver the notebook tries to get an ip adress which does not work.. so how can i arrange the two components? any ideas? sorry for my bad english...
THX Sebastian
5 Suggested Answers
  • 76 Answers
SOURCE: Problem with Canon I-SENSYS MF 4150
Wondering why you changed to a new Canon driver? With the new driver, this print server may not work, no IFs, ANDs or BUTs. Most print servers (not all though) don't work well with a multi-function printer. This one probably changed due to software programming in the new driver. All you can really do is return to the older driver, or buy another type of print server. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
  • 1056 Answers
SOURCE: No Ports available
The default IP in the D-Link router is 192.168.1.x
The default IP in the Edimax is 192.168.2.2
Your 3rd octet (the # after 168) has got to be the same for the two of them to communicate.
So, you can either reIP your router, or connect your PC to the print server and change it. The software for the print server should have a tool for finding the PS by MAC address, then you can go in and reset it to 192.168.1.x
Posted on Sep 17, 2008
Pinky01
  • 209 Answers
SOURCE: Ubuntu 8.04 x64 not connecting
Ubuntu has his own print server. When you click on System/Administration/Print (not sure, because I use the French version :Impression), it opens a window. Then you select Go to the server (again, something similar to that choice), and you can configure the options for the server.
Posted on Nov 22, 2008
  • 3 Answers
SOURCE: PS3207U problem with HP 1060
Same problem with a Hp 3300 and a Hp960c, both of them plugged and recongnized by the unit, there was no way to print.
Then I upgraded the unit firmware to version 1.3 and now both printers are working!
Posted on Apr 02, 2009
I can't get my computer running windows 7 to recognize the printer
Z6M+ printer doesn't have USB port, how do you connect this printer to Win 7 PC? if you are using parallel / serial converter to USB then good luck. Ideally to get zebra external printserver and connect the printer through the network.
Sep 25, 2013 | Zebra Z6M Plus Thermal Label Printer
Printers are not recognized as online by printserver
Have you check which port your PC trying to register your printer to?
Sep 22, 2007 | D-Link DPR1260 Rangebooster G...
My printerserver doesn't show up on my network (working properly). I am using Windows 7 ultimate, Thomson TG585 router, NC-2100p, Brother 1030 (installed as 1430).
hi marc,
good day!
You can power off the Router and Printserver..then test the printserver if still detected on computer,direct testing on computer first..then if it is good,check your network if running good and have an IP addresses..check the IP of printserver too..name it as you like.
mastergani
Jan 08, 2011 | Brother NC 2100P (NC-2100P) Print Server
Setup stops at printserver will connect to your wireless network
hi
thank you for using Fxiya
go to folowing link you will find complet stup for Linksys printserver
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
May 15, 2010 | Linksys WPSM54G Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
The printer is not communicating with the computer. all cables are plugged in correctly
if you are using a printserver to connect the printer to a network, please have the printserver reinstalled then reinstall a compatible printer driver on your computer.
if this is a straight com on your computer, please have the drivers reinstalled and have the uptodate drivers loaded
Nov 12, 2009 | Dell 924 All-in-One InkJet Printer
8870DW scan function does not work with macBook using USB
You must reinstall the software on the computer to which the printer is physically connected. i think u are using usb to connect to computer so to share it out u most buy printserver or use let the computer where its physically connected just to be on and u share there the computer to your workgroup computers
Dec 27, 2008 | Brother Multi-Function Center MFC-8870DW...
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
PSUS4 problem "talking" to Canon S330
Hi dreaddymck
I need a little more information on the setup. Is there a router in your network? If there is, is your PrintServer connected to the router and your computer is attempting to connect to the printserver through the router? If there is no router and your PrintServer is connected to your printer via the USB port and your computer is connected to one of the ports on the PrintServer via a cat5 cable, I would check to see whether you are actually communicating with the PrinterServer by pinging its IP address from the computer. If the ping is successful, then I would look at the printer properties in your computer's printer control panel and check the port configuration. Usually it is shows the IP address, port 9100 and port protocol is usually set to RAW. Otherwise I would attempt to reinstall the PrintServer using the CD originally provided. It appears to me that the server may not be publishing its IP address on your network.
--RoadHawk
Nov 27, 2007 | Linksys PrintServer for USB with 4 port...
Edimax PS-1203 Print Server Logo
74 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
