Question about SINGER 7470 Sewing Machine
How to "serge"
I watched the demo on this machine and the fellow was using the serge stitch. The manual, however, does not mention any stitch settings to serge. Is serge known by another name? What are the stitch settings? Do I have to use the cutter to serge? Thanks
When serging with stitch finger in, the thread wraps around it about 20 times causing a jam. What to do? Also, can I serge without the stitch finger in?
Don't know what machine you have. With my machine, I can pull the finger back a little so that the thread still wraps around it but is able to slip off the end of the stitch finger, ie do not push the stitch finger all the way in so there is no outlet for the thread. You can serge without the stitch finger, but it does change the character of the stitch, ie it may cause the fabric edge to buckle.
Jul 06, 2018 | Sewing Machines
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
I have a Necchi Royal Series 4795 and I can only use a straight stitch. How do you set this machine to other stitches(hemming,serging)? just need to know what dials to set for which stitch & what foot
try --www.yumaeng.com-- for a pdf version user manual for the machine
that should give you all the information on what to do for the stitches you want
go google and type in ---user manual for necchi sewing machine model 4795-- as there other sites with user manuals as well
Jan 04, 2017 | Necchi Sewing Machines
How do I use the patterns (marked pattern selection) on front of machine. User manual does not tell how and company does not have any other information on this.
It appears that your machine basically does variations of 2 stitches: straight stitch and zig-zag, plus buttonholes. Take some time to learn your machine by downloading the Workbook (Wkbk) and working through it doing the various stitches on your machine. You will eventually figure out how to combine different selections to achieve the stitches you want. The owner's manual will show you which basic settings will make which stitches.
Instruction Manuals
SINGER 5830C Quick Sales Demo Part 1
Jan 02, 2018 | Sewing Machines
I have a new Viking Huskylock S25 and the serger tensions are off and I cannot get them adjusted.
How do you mean the tension are off? A serger should have 3 or 4 tension knobs (although yours looks like it is push button digital settings) and generally from new these will produce a standard stitch when all are set to 5. Are you sure that you've got the thread pulled into the tension discs fully? Check each one by pulling on the thread below the tension disc and feel for resistance, if the thread pulls very easily, then recheck and thread again.
Have you got the thread aerial raised up to the full height? Remember also to put the plastic cone holders under the thread cones as you want the cone to stay still and the thread to feed off it - it does this very fast, sergers sew at 1500 stitches per minute so the thread streams off the cones very quickly.
Using a serger is quite different to a sewing machine and your model looks like its one of the later computerised ones with multiple stitch options including coverstitch. I'd suggest that you go back to your dealer and ask to spend time with them for a demo, thread up in front of them for pointers or take a class to familiarise yourself fully with the machine. Then go home again, break out the manual, and go through threading up from scratch several times until you've got it off pat. Remember to thread top looper, bottom looper, left needle, right needle in this sequence always, then pull all threads under the foot, lower pressure foot and serge off a short chain. To change colour thread, you can always cut and knot on new threads, turn tension down and pull through the loopers, but you've got to thread the needles fresh each time you change colour.
There is some good videos on You-tube, Nancy Zieman has a several and she's also written several books on using a serger and obviously the manual is first point of reference.
Each fabric will behave differently so for each new fabric, you will need to adjust tensions and move the blade to get it stitch and just encasing the cut edge at a suitable width. To work out how it should look, break out some ready to wear garments and have a look at those seams, then test and practice with your machine to get a similar stitch. Always test serge two thickenesses if you are going to use it to construct your garments and pull open from the right side to ensure the needle thread is tight enough so the seams don't pull open under wear.
Good idea to keep your test seam samples in a notebook and write down the settings you used for reference next time. I have to say, I've done flatlock with silky decorative thread once in 19 years - but I do know how to set up the machine for this. However, rolled hem with wooly thread is very useful and I often use this to edge hems. I'm envious of your coverstitch option, this is great for hemming and necklines and is something early sergers didnt do.
Just checked out this model on an Ebay vendor's site and it mentions a training DVD, you've got several different stitch types to master with this machine so there will be some learning and practice involved to get it right. Good luck - I hope this is of some help but I'd be visiting the dealer for specific help if you can.
Apr 29, 2011 | Sewing Machines
Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Mar 13, 2010 | Simplicity Serge Pro SW432 Mechanical...
I need help with the tention settings on my simplicity serger pro please
All the problem that everyone had with the Simplicity Serge Pro are able to be fixed with the manual. I downloaded the manual from the Simplicity Home page: www.simplicityhomecare.com. That simple. Thank you for your assistance because you made me realize that I had to go get the answer myself if I wanted to get anything done yesterday. Waiting for 24 hours was just too long for me. There is also an 800-822-6691 hotline as well. I have already finished my project. Have a great day!
Nov 03, 2008 | Simplicity Serge Pro SW432 Mechanical...
SINGER 7470 Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
