Question about Toshiba 57H81 57" Rear Projection Television
Touch Focus/manual convergence
When I press the touch focus button, a message appears saying " Toshiba Color TV Advance Technologies" but I cannot access the convergence screen? The same happens when I try manually.
  • thekid62 Dec 23, 2007
    I have went into manualy adjust the colors and the red X wont move up
    President:
  • 4,402 Answers
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2007
Toshiba 50hdx82 tv touch focus error blue is bowed.
Convergence is dead.Know how to solders.Must replaced the 2 Convergence ICS,and all it resitors.To do it ur self repair buy a convergence kit at Tv repair World.com,Repeairkits.com.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Toshiba 50HDX82 50" Rear Projection...
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
I have a 57'' Toshiba HDTV and my picture is showing double and green and pink hues. When I press my touch focus button it says there is a touch focus error. What is the problem?
most likely it is the convergence IC'S
IF you are handy you can google complete tv kits for this problem, Good luck
Larry Dillon
Aug 11, 2009 | Televison & Video
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
57H81Toshiba Blue Line not straight
You have a bad convergence output IC in the blue vertical circuit. On the bottom side of the chassis you will see a " V " printed by the heat sink. You will need to unsolder the heat sink and the 20 pins on the IC to remove it. Replace with STK 392-180 (sanyo) if possible or STK 392-150. Looking from the rear the heat sinks are big aluminum finned rectangles. There are 2 heat sinks one marked H and one Marked V. Even though you have a horizontal line your problem is in the vertical IC. Be sure to use a liberal dose of heat sink compound.
Mar 21, 2008 | Toshiba 57H81 57" Rear Projection...
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
TOUCH FOCUS ERROR
The convergence IC`s need to be replaced and the related low ohm resistors need to be checked for proper value.
Oct 15, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
