Back light and odometer reading lights up but speedo needele and odometer does not turn
SOURCE: sportster sport sppedometer problem
replace TSSM this module uses speed sensor to trigger cancel.
SOURCE: Speedo, turn signals, brake lights, horn stopped working. All else is fine.
Gap your plugs to 38 thou. Check all your bulbs (one burned out will affect the rest) Take a look at all your fuses and make sure they are all ok. Otherwise you are probably looking at a wiring short which will require trouble shooting of the elctrical system. Buy your self a service manual for your bike, this will help you a lot.
hold key fob until signals flash,check speedo for solid key light,then try...if it still does the same thing,battery could be too low(will cause this also)
SOURCE: Speedometer stopped working on my 97 sportster
Your speed sensor is probably bad, common problem. It's oblong, located near the starter, has one screw holding it in and has a length of shielded wire that goes to a connector. Replace. Can only be tested by replacing with a known good component.
SPEEDOMETER TROUBLESHOOTING
Can
be loose speedo wiring connectors under instrument panel or its issue with
speed sensor on transmission.
I
suggest you to go through help links mentioned below with appropriate solutions
to confirm the problem :------
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
1996 fiat bravo speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.ht
Speedometer not working on 1993 Ford F350?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
ABS & Brake lights warning indicator steady on dash and
speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works
intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
These
will help.
Thanks.
