Question about Garmin StreetPilot C330 GPS Receiver
Will not come on or only for 1 second
Was working fine for 1 year then went on trip, when turned on to return home unit came on for about 30 seconds and went off. have not been able to get it working again.
When i plug it into computer at home it seems to work part time, will light up and give choices of maps etc.
have tried reset
  • 83 Answers
It sounds as if the battery is not charging. Leave it connect to a turned on computer overnight and try it after a full nights charge.or about 12 hours. Let us know if this doesn't work.
Thanks for using Fixya.com
Harleyknut
Posted on May 14, 2009
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
RCA HD52W59 Turns Off
Hi, Based on your post/description, my guess is a loose connection or a cold solder problem (higher probability). Not unless you want to make another "30 mile trip", you have to find a local tech who is comfortable working with live/hot sets. The usual precaution on working with live/hot units and HV applies. This involves opening the back cover, powering the unit and with a foot long + insulated rod (I use a broken fiberglass fishing rod), poke around the inside of the TV, part/move the wires about, also press on the boards slightly. The idea is locate the loose connection or the cold solder. Soon as located, poweroff and resolder. If there is a component/board failure, the unit would not have operated intermittently. There is a big chance that the loose connection or cold solder just worsened and that cause the recent "chosen not to work". Further, the power light still turns on and you have not posted any other indications such as a beeping sound or blinking leds/lights which normally indicates failure. Hope this be of assistance/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Garmin StreetPilot C330 GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
