Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My CE 200 jammed and I cleaned it out now it won't pick up bobbin thread how do i reset the timing?
    Scholar:
  • 79 Answers
To reset the timing on your machine there are timing marks that show you where the machine must be set.
Remove the needle plate and bobbin case. Turn the hand wheel towards you until the needle bar is in the lowest position. You will see two marks on the needle bar with the top one being flush with the bottom of the bushing. If it is not, loosen the needle bar screw and move it up or down to set the marks. Make sure you keep the needle bar straight (needle clamp screw should be straight to the right).
Next turn the hand wheel until the lower timing mark is flush with the bushing. At this point, the hook tip should be just above the eye of the needle.
If the hook tip and needle do not line up, turn the machine on its back making sure the needle bar does not move. Loosen the two timing screws on the hook pulley (only loosen them 1/4 turn). Move the hook to line it up with the needle. Tighten the screws and recheck the timing. The feed dogs should be in the down position when timing the machine. If the feed dogs are up when the timing is done, the hook timing is out 180 degrees.
Posted on May 14, 2009
Thread breaking
Can you please tell me what is the model no. and the brand so that i can help you fix the problem.
Waiting for your reply..
Feb 24, 2008 | Singer CE-200 Quantum Futura Computerized...
Does not stitch, just beeps
try changing the needle
try rethreading the machine top -make sure to use every thread
guide & bobbin--make sure the bobbin is turned the right way in the
bobbin case
clean under the needle plate & in the bobbin area for lint
also try turning the machine off & then back on & see if that will
help
Oct 07, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer ce-200 jerks between stitches only when it goes slow.
Are you using a good quality bobbin thread? Is the machine cleaned and oiled? Is the bobbin in place like it supposed to be?
Oct 31, 2011 | Singer CE-200 Quantum Futura Computerized...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin thread not feeding properly
The tension used to wind the bobbin is not wright, remove all the thread and rewind the bobbin. Make sure that you put the bobbin in place exactly as shown on the image, I didn't in the beginning and couldnt figure it out, now I now IT IS VERY IMPORTANT TO PLACE THE BOBBIN CORRECTLY.
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
BOBBIN SLIPPING AND STOP EMBROIDERY
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Aug 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
549 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
