Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hoover U5237-930 embedded dirt finder
The finder stays red on "HI" and may flick to green then back to red on "Reg."
I broke it down to the sensor that doesn't seem to be optical and cleaned things.
The sensor is located just above the orifice that enters the bag.
I assume it must sense vibration.
Any recommendations?
informatica
  • 1114 Answers
SOURCE: need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
Buffalo12980
  • 625 Answers
SOURCE: Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Posted on Sep 22, 2007
  • 3 Answers
SOURCE: embedded dirt finder light stuck
Try cleaning out all the pathways you can get to. Trapped particles can mess up this indicator. Particularly check the extra mesh filter that is under the bag (there's a plastic grid that snaps over it to hold it into place). Clean that out and make sure the bag is securely in place.
Posted on Dec 23, 2007
  • 126 Answers
The Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Posted on Jan 20, 2008
SOURCE: My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Posted on Jan 20, 2010
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
Hoover - Red Light Dirt Sensor
check to make sure the settings didn't get inadvertently switched to the hi position, move the switch back and forth from high to reg a few times, then leave it on reg.
remove and hand wash the primary filter and secondary filter, dry throughly and replace them in the vacuum.
if none of this works, you will need to have the vacuum serviced, or if it is still working, just don't pay attention to the dirt-finder. the dirt sensor on your vacuum is located in the suction tube and is generally not accessible enough to clean without taking the vacuum apart.
hope this helps,
trin
Nov 20, 2007 | Vacuums
Dirt finder sensor stopped working
I had the same problem with a hoover windtunnel 6200 - u5477-900. I removed the flexible hose from top of the plastic tube running vertically along the right side of the back of the vacuum. When I used a flashlight to look into the plastic tube, I could see a clog at the bottom, where the flexible hose curved frontwards towards the brushes. I then removed the 2 screws holding the vertical plastic tube to the vacuum. When I disconnected the plastic tube from the flexible hose at the bottom, I found a clog of dirt and dog hair. After removing the clog and reassembling, the clean / dirty light now moves back and forth from red to green.
Jan 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Embedded dirt finder light stuck
Dec 31, 2007 | Vacuums
Dec 04, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Problem with embedded dirt finder
Take the hose off at the back of the vac, should just turn then pull oull, look down inside the tube that the hose was connected to, there is a sensor there and if it is coated over with dirt, then it can't work, Clean it off and the try it, if it still stays on, then you have a bad sensor, and if this is less then a year old, you have a one year warranty on this. Take it to a warranty shop and take proof of purchase with you.
Oct 24, 2007 | Hoover U6630-900 WindTunnel Bagless...
Dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Oct 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Embeded Dirt Finder
Sep 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Savvy
Does this happen at both Dirt Finder Sensitivity settings?
Sep 16, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Embedded Dirt Finder green light won't come back on - stays red
The dirt sensor is a motion detector. After it gets dirty it will either stay red or stay green. You can have the vacuum serviced at your local vac shop and possibly get this fixed. Sometimes they are as good as new and sometimes they are not repairable. It will not effect anything else though.
Jun 09, 2017 | Hoover U6634-900 WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
488 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
