Question about GE Refrigerators
Water leaking from overflow tube
I have a GE GSL22JFTA side by side refrigerator. I was having a problem with water (ice) building up in the bottom of the freezer. I removed the inside back panel, and defrosted the coils. That fixed that. Now the overflow tube on the bottom backside of the unit is leaking on my floor. It is going to ruin my floor. Any suggestions...PLEASE!
  • wirefire May 12, 2009
    It actually seems to be dripping from the end of the hose. Could it be when I defrosted the fridge that the overflow filled and now any additional overflow is causing it to drain onto the floor?
    Guru:
  • 1,524 Answers
Pour warm water and baking soda down drain and look for cracks in tube.
Posted on May 12, 2009
  • Robert Moller
    Robert Moller May 12, 2009
    Yes, but follow through with the flushing as it will keep the drain clear. Also if you can wrap a piece of wire around the bottom of the defrost heater and let it hang down the drain tube this will prevent freeze ups.
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile Arctica refrigerator - water is leaking from the punctured plastic hose going up to the water filter (plastic hose from the bottom of the solenoid goes into refrigerator assembly)....
Good day!!!!
Refrigerators with a defrost cycle drain the melted water from the evaporator coils through a tube or a hole into a drip pan underneath the refrigerator. The water usually evaporates, but most times the pan is removable and can be drained. If this path of water is blocked at any point because the drain hole or tube is crimped or clotted with anything, it will back up inside the refrigerator area and try to find a way out, usually under the crisper drawers. To fix this, clear the obstruction in the drain tube. The drain pan at the bottom of the refrigerator can overflow or get old, crack, and develop a leak. Other times, mold can grow in the drain tube and clog it. Most refrigerators have an ice and/or water system built into them. This means that you have a waterline attached to the back of your refrigerator and it comes out as ice or cold water. Anywhere that water travels through the refrigerator and freezer can turn into a leak. To find the leak, you need to follow the tubes that carry the water through the appliance and make sure that all connections are tight.
Leaking containers or spills in the refrigerator can be misdiagnosed as leaks. First make sure that there are no puddles of juice, milk, water, etc. on one of the large capacity shelves.
I hope this solution will be helpful...Thanks for using fixya..
Aug 31, 2011 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side Model # TFX25PPBAWW Serial # GT257367 Water leaking out the front freezer side. Ice is accumulating at the bottom where water is poolling. I have removed the Ice maker from the freezer...
You have two things causing this
1) the water valve for the i/m is seeping and not fully closing,with the i/m removed no water should come from the tube and the valve should be replaced(alos it were the from the im their would be ice build up from that tube all the way down to the very bottom)
2) this is the most prabable cause with the abense of ice build except at the bottom around the lowest drawer and that is the defrost drain is blocked,the drain can be found at the very bottom of the rear panel of the freezer and is blocked so instead of the defrost water draining it is pooling at the bottom then running out all over the floor
to clear the drain push a wire hanger through the tube till a small hole opens then flush it with hot water
Jul 19, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking out of the bottom of my ge refrigerator.is there a tray that I need to empty? cannot locate one.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
We have a GE profile that we bought in 2007. We
Hi Sandy, I can assist you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jun 19, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
320 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
