Question about Freezers
Stops working after a week then will work again
It will work fine the the over load kicks it off after a week if you turn it off then on you can hear the over load click if i leave it off for a few days it will work again for about a week or 2 then do it again took relay and overload off and they look fine and working at this time could it be a bad overload or relay if not should i check the draw of the comp when it acts up and what should the max draw be?        thank you
  • cityman132 Oct 14, 2007
    Frigidaire mfu12m2gw2
  • cityman132 Oct 17, 2007
    thank you i will try it and let you know how it does in a couple of weeks. thanks again
  • 447 Answers
It sounds like the compressor is starting to get a little worn out and needs some assistance starting. This is achieved by adding a start capacitor via a Supco RC0810 3n1 start device.
Posted on Oct 15, 2007
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
Hi, i have a Hoover HCA 36 FT ALU fridge freezer, a few weeks back it started making a wheird high pitched gurgling noise, a yesterday it stopped working. If i switch it off at the mains and then back on...
Sounds like a capillary issue. The capillary tube is the metering device for the refrigerant.... a long tube with the bore measured in thousandths of an inch. If it has become restricted, it could well be overloading the compressor on start-up if the pressures on the high and low sides of the system do not equalize. In my experience, this is quite common on systems utilizing R*134A, especially if the compressor has overheated previously. You may well need the services of a refrigeration technician.
Jun 18, 2011 | Hoover Freezers
My freezer N308 F&P makes a little noise but motor not going. It is slowly starting to defrost and water coming out...I turned it off and on but same.
The compressor could be gone, the niose you hear will be the internal fan unit running , this circulates the cold air arount the inside of the unit. If this unit has a timer, it will be a located in the compressor housing well in the lower rear of the , it will be separate from the compressor and will have 5 wires plugged into it, on that unit, locate a small round knob and turn it clockwise, it should start, if it does, replace the timer, if not, check the thermostat. This may need a tech to do safely as you are working with a live curcuit.
Hope that helps but without being there it quite hard to explain.
Dont forget to vote and goodluck, need more help contact me wgheaven@yahoo.com.au and if you are in Perth Australia, I can have a look at it.
Mar 22, 2011 | Freezers
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Mar 27, 2017 | Kenmore Freezers
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Fridgidaire chest freezer problem
go to your local appliance store and buy a 3 in 1 starter kit,install, directions are with kit,this is your last hope as the compressor is getting weak,hope this help-mike
May 21, 2008 | Freezers
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
Hotpoint 25.3 cu. ft. not cooling
When the freon as been recharged, did the dryer been replaced?
Nov 25, 2007 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
Freezers Logo
635 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
