Question about Epson Stylus CX5400 All-In-One InkJet Printer
Nothing happens when i hit the scan button on my epson cx5400
Hi ........when i press the scan button nothing happens
    Scholar:
  • 134 Answers
You need the proper driver for the scanner which is compatible with your operating system.
what is the full version of your operating system?
You can download the twain driver off the support.epson.com site.
if you need more assistance please let me know.
Posted on May 13, 2009
I can't find any instructions on how th scan on my epsom bx300f printer. Nothing on the machine's menu. I've done it before but cant remember how. Can anyone help.
It seems that you have not installed drivers for your CX5400 in your PC. Please install it and then you will find an interface for the same.
Nov 12, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How do I scan a document and send it via E mail? this is a Epson stylus CX5400.
If it has a scan button on the printer try that. If it came with any software you should be able to scan using that. Then just add the scanned document as an email attachment
Sep 22, 2009 | Epson Stylus CX5400 All-In-One InkJet...
EPSON Scanner 4490 Problem
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
Scan light
HI-
Yes the bub for it needs replacement. please consult a service technician that is accredited by epson, you can check one on your area by going to www.epson.com site and look for a servicer.
Hope this helps
Sep 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400
change your printer adaptor & make sure that the input & output voltages & the current ratting are of the same value as the before.thanks.
Aug 01, 2008 | Epson Stylus CX4600 All-In-One InkJet...
CX6600 SCANNER
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Jun 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
LOST DISC
Need to download and install scanning software and driver
click here to go to Epson driver download
Nov 15, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
157 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
