Question about Nikon Coolpix 4800 Digital Camera
Camera doesn't get past welcome window with memory card installed
After installing an SD card, the camera will not get past the start up window, and none of the buttons work. I have to remove the battery and the SD card, replace the battery, then the camera works fine using the internal memory. Re-installing the memory card locks it up again.
  • kneehole_1 May 12, 2009
    Yes, tried a 128 Mb PNY and a 1 Gig SanDisk. Both do the same thing. Camera reads anything up to 1G.
  • 150 Answers
Have you tried another brand of memory card ?
Try a memory card from a friend that has been used for a while. If it locks up with other cards then you have problem with camera. Check if needs to be set to read from memory cards above certain sizes ?
Posted on May 12, 2009
Want to know which digital cameras are compatable with windows 8
Are you saying the supplied software does not install in Windows 8? Being as the camera uses SD memory card, SDHC memory card, SDXC memory card, then Windows 8 will be able to read those cards. As for which cameras are compatible with Windows 8, they all should be.
Apr 05, 2014 | Quantaray 28-300mm F3.8-6.3 Autofocus Lens...
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
Note if sd card is installed is on the screen wont advance past that DGS 160. I have tried different SD card, hard booted, changed batteries, when I plug into computer interface, it doesn't recognize ...
Do you mean the DGS I-60? What size memory card are you using? The I-60 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 15, 2013 | Moultrie MFH-DGS-200 Digital Camera
Camera fails to acknowledge memory card
Try cleaning SD card connectors with clean rag, and blow some dust out of a SD card connecting place, if it doesnt work try checking that SD card on some other camera, if it works take your camera to service, if SD card doesnt work on othar camera than SD card is broken.
Feb 16, 2013 | Kodak EasyShare One Digital Camera
I need the user guide for my Vivicam 8340 digital camera, since I want to install an SD card on it but I don't know how to do it. Thank you, in advance!
The user guide is not available online as a download. However installing an SD card is usually pretty simple. On this camera, the SD card slot is on the bottom inside the compartment where the battery is housed. Simply slide the door open, and locate the slot for the memory card. The memory card should only go in one way, so don't try to force it. If it doesn't fit fairly easily try turning the card around. Remember: the gold pins on the card go into the camera!
May 05, 2011 | Cameras
I can't get my daughters pictures to come up on my computer. what am i doing wrong?
Hi - I am not familiar with this camera, but it appears many users have encountered similar downloading problems.That is too bad - kids should not be made to feel cheated out of the wonders of technology.
1- Connect the camera to the computer and put it on. Go to Start/ My Computer  If the camera appears as an external memory volume E: or D: etc. , click on the icon and on any folders inside. The photos should be there. Copy the entire folder enclosing the photos (right-click/copy)  and paste it in any other folder where you have your files for example on the desktop.(right-click/paste).
2- If the camera does not appear in My Computer in step 1. check if it has a removable SD memory card. If it has one take it out of the camera and put it in an SD card reader (some computers like the iMac and other laptops have an SD card slot built in the side) . Connect the reader by its USB to the camera and check My Computer as in step 1.  Since the camera has a built-in memory as well as the SD card the photos you want may  be on the internal memory. So you need to go to step 3.
3-  If the camera does not have an  SD card, then your only option is to check the camera driver installation, and use. The manual and the following pages should help: Good luck it is frustrating to deal with driver problems.
http://www.fixya.com/support/t319068-download_photos
http://reviews.cnet.com/digital-cameras/disney-pix-micro-red/1707-6501_7-32159741.html#userOpinions
Dec 20, 2010 | Disney Pix Micro Digital Camera
My sandisk sd card isn't working in my camera. My camera is a vivitar 5024 camera, everytime I try to take a picture it says memory card is not ready, it says switch to internel ram. This memory card is...
Have you tried to format the card.
1.
  • Start up a computer with Windows XP, Vista, windows 7or Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
  • 2Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
  • 3Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
  • 4Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
    If you need further assistance please feel free to let me know. Thanks and have great day, Midwest-tek
  • Aug 31, 2010 | Vivitar ViviCam 5024 Digital Camera
    Cannot install driver (code 10 )
    don't use the camera to load the pictures. see if your printer or computer have an SD card reader or buy one for $10 plug it into your USB drive and access the pictures that way...
    Once you plug in your SD card Via SD card reader go to my computer and open the drive with the SD card on it... Shouldn't be difficult to figure out. Cut or Copy all your pics and paste them into your My Pics folder or any other folder of your choosing. Enjoy your pics...
    Jun 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
    Camcorder not reading memory card
    It seems to be getting on for ten years old now - replacement would be cheaper than repair.
    Apr 01, 2017 | Mitsuba DV5 Camcorder
    Memory card
    Hi and welcome to FixYa.
    Your camera will not work with an SDHC card. It must be an SD card.
    Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
    Thanks for coming to FixYa, and feel free to rate my solution.
    Rob
    Jul 28, 2008 | Pentax Optio T10 Digital Camera
    Nikon Coolpix 4800 Digital Camera Logo
    102 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
