Question about Insignia 37" LCD Flat-Panel HDTV
Insignia ns-lcd42hd screen flutters
The tv is just over a year old. Went on vacation for a week, when I came back I turned the tv on..and the picture was all outta control. It was like someone was playing with the vertical hold. The picture just flutters up and down. It does it randomly. Will do it for 2 seconds or for 2 hrs. Some times turning off the tv fixes it, sometimes it doesnt. Will go for days sometimes without doing it as well. Of course my 1 yr warranty expired 4 weeks before this happened and neither Best Buy or Insignia will do anything about it. I've ruled out the cause being anything other than the tv, it does it with cable, xbox, ps3 inputs. It does it when nothing else is on as well...as soon as the tv comes on.
  • brainwraps May 13, 2009
    Thanks.....even though you are waaay over my head with all that. Is this normal for a tv barely a year old?
    President:
  • 814 Answers
This television is having trouble with sync circuits. It probably has some component adding erratic noise voltage to the circuit causing the instability in the sync lock circuits. The solution is to locate the bad component with an oscilloscope by following the signal path with oscilloscope probe until you find the irregular signal and then replace the part. This part could be either capacitors or ringing resistors.It may also be a component in you solid state signal processor. You should have it tested in a service center and see if they can locate the bad components. Then see if it worth replacing with the cost of parts and labor. Hope this helps you with your problem.
Posted on May 13, 2009
  • stoneheaded May 13, 2009
    No This should not happen with quality components, but these products are on a very low level of component quality. Being made in china does not make a difference. They make high quality products for high quality manufacturers, like Sony and Toshiba. Unfortunately this is a Best Buy house brand and , they are in the business of selling products, so you do not get high quality. You can tell the level of quality of the products by the manufacturers warranty the longer the warranty the better the product. You should always buy extended warranties for these cheap products to avoid the low level component problems used in these type of products. Hope this helps you with your problem.
Insignia tv reset
Internal problem in the TV is enabling the protection circuitry. If repairing yourself, start with the power supply.
Aug 28, 2014 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Tip
REMOTE CONTROL CODES FOR THE INSIGNIA TELEVISION MODEL: 42" NS-LCD42HD
This information was found on the insignia website www.insignia-products.com under technical information for the insignia television model :42"1080p NS-LCD42HD. cablevision-ur2-cbl-cv04.gifaligner.gif CableVision UR2-CBL-CV04
code: 096
charter-digital.gifaligner.gif Charter DIGITAL
code: 0463
comcast-m1057.gifaligner.gif Comcast M1057
code: 0463, 10463
cox-cox.gifaligner.gif Cox COX
code: 0463
direct-tv-rc23.gifaligner.gif Direct TV RC23
code: 10463
dish-network-vip508.gifaligner.gif Dish Network VIP508
code: 720
dish-network-vip622.gifaligner.gif Dish Network VIP622
code: 720
motorola-drc800.gifaligner.gif Motorola DRC800
code: 0463
one-for-all-urc-6690.gifaligner.gif One for All URC-6690
code: 0464
phillips-pdvr8.gifaligner.gif Phillips PDVR8
code: 115
phillips-ph5dss.gifaligner.gif Phillips PH5DSS
code: 115
phillips-ph5dvd5.gifaligner.gif Phillips PH5DVD5
code: 115
phillips-pmdvr8.gifaligner.gif Phillips PMDVR8
code: 115
rca-rcu807.gifaligner.gif RCA RCU807
code: 135
sony-rm-vl600.gifaligner.gif Sony RM-VL600
code: 8043
tivo-hd.gifaligner.gif TiVo HD
code: 0091
tivo-series-3.gifaligner.gif TiVo SERIES 3
code: 0091
on May 23, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a insignia ns lcd42hd 09 tv that on the left half of the screen has ghost images and sometimes vertical lines in it and i noticed when i shake it the screen goes back to normal but i have to do this...
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Sep 07, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I have sound and picture distortion (like what happens during a thunderstorm) in my 42 inch insignia lcd tv but not during storms. started about two weeks ago, happens intermittently. driving me nuts. is...
Your probably having what cable guys call a SNR ( signal to noise ) issue. There's no way to know unless you call your cable provider. The SNR should be 32 and above with zero pre/post errors. In case you want to ask the tech what they are.
May 18, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Color went bad it is ok for a few minuites then it goes bad
That looks like a loose cable to the LCD controller. Next time it goes bad gently tap on the sides of the screen and see if the video becomes normal. If it does then its confirmed that its caused due to a loose contact. Slowly unplug the LVDS cable from the LCD controller board and plug it back in. Make sure you do not touch anything else. Also turn off the tv and unplug from the power supply before you begin.
May 28, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Hello, I have an ns-lcd42hd Insignia TV I'm looking for the part number for the factory remote.My son lost it and I'd like to purchase a new one thank you
As for the part number... not sure. But you can purchase a new remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NS-LCD42HD-09&uuid=12749564580310
May 27, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I purchased this hdtv new from Best Buy in February 2008. Last week a crackling sound began to develop and now the sound has gone completely, although the picture is fine.
Insignia T.V. 50" Model; NS-PDP50, Plasma T.V.
T.V. comes on, there is sound but no picture.
T.V. is les than 18 months old. We use the T.V. when we come to our Condo in Daytona Beach for vacation, so it hasn't been used very much.
Jan 10, 2010 | Insignia LCDTV26 26 in. Television
No picture
if the power led is on then thats the only fuse/if you get sound no pic then its the invertor board/switch it on does the screen flash for a second/can you see pic with a torch in background/open it get invertor board no if so
Jan 05, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
RE; NS-LCD42HD-09 THE COLORS ARE TERRIBLE. THE
Here are some preferred settings for the same model in 32" It should get you close enough to fine tune from.
  • Picture Modes
    • Picture Mode : N/A
    • Color Temperature : Warm
    • Aspect Ratio : Wide
  • Precision Settings
    • Contrast : 60
    • Brightness : 50
    • Color : 52
    • Tint : G1
    • Backlight : 3
  • Advanced Video Menu
    • Noise Reduction : Off
    • 3DYC : Off
    • Dynamic Contrast : Off
Dec 25, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
NS-LCD42HD-09 Insignia. The power light is on, but no sound, no picture. TV is 13mths old. Best Buy junk I'm guessing, but as a electrical engineer, I'm determined to fix it myself. I think it's the power...
At least the 5VDC stand by power supply is working, there will be a control signal pin from the mainboard to the power supply board to turn on the rest of the power supplies (24vdc for the back light inverter boards, 12vdc for other circuits). Any bulging caps in the power supply?
Nov 24, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Insignia 37" LCD Flat-Panel HDTV Logo
313 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
