Question about Samsung TS-H542A DVD±RW Burner
Computer turns off due to new installed hardware (cd-rom drive)
I have put in a new cd-rom unit in my computer, but when it starts going my computer immediately turns off. any suggestions?
  • 4 more comments
  • henrikp89 May 12, 2009
    when I unplug the unit, the computer works just fine..
  • henrikp89 May 13, 2009
    This one is the only unit of that sort in my machine. I inserted it in another machine and there the unit worked perfectly fine..
    My power supply is on 350W, could the reason be that it isn't enough to make my computer happy? Some other specifications:
    AMD X2 Dual Core Processor 6000+
    2x1024MB Ram
    380GB Hard Disk Drive
    Runs with Windows XP
    2x1024MB Ram
    I have now also tried another IDE-cable and to disconnect one of my hard disk drives in order to minimize the use of power. But the computer still turns off about three seconds after pushing the power button.
  • Jerry Naidoo May 11, 2010
    Unplug the new unit - what happens ?
  • 150 Answers
Then only one more check to do before we can fault the new unit , the new unit should have jumpers at the back of it. If it is the second unit of that type installed ensure the jumper settings is set to slave and not master which is default. If it is the only unit (cd rom/dvd rw) then you have a faulty new unit. Best way to is to insert in another friends machine to double check before taking it back.
Posted on May 12, 2009
  • Jerry Naidoo May 13, 2009
    Very unlikely , one sure way to know is only plug in the new unit to the power supply and switch it on and check.
I need to know how to set up new hard drive after fitting please
do you know how to go to setup section as computer opens?
Some computers you press DEL key others F2 others F10
when computer is just starting.
go there and confirm the disk is visible to hardware.
In the same location ensure you can see cd/dvd ROM
in the same location make the cd/dvd ROM to be first when starting up computer.
save changes if need be.
put your cd/dvd ROM with starter operation system (assuming windows)
and load your computer.
Aug 04, 2011 | Packard Bell Computers & Internet
Hi, my Acer laptop won't show any CD Rom icon on the screen in Linux Mint but I had windows vista installed there before (it was the original OS) and the computer was turning itself off every ones in a...
if it did turn off with a bsod(blue screen of death) then the problem was with ur hardware or the hardware drivers in this case the rom drive
consider a replacement of the drive if it's in warranty but before that try updating the drivers of the rom
May 02, 2011 | Acer Aspire 5610-4648 Notebook
Hp ml350g4 p server hang on diagonestic screen, unable to set standard boot order(ilo)
To repair your installation of Windows, follow these steps:
1. Insert the Windows Server 2003 CD in the CD-ROM or DVD-ROM drive.
2. If the Windows CD displays the What would you like to do? menu, click Exit.
3. Turn off your computer, wait ten seconds, and then turn your computer back on.
4. If you are prompted to start your computer from the CD, do so.
Note You must be able to start your computer from the Windows Server 2003 CD-ROM to run Windows Setup. Your CD-ROM or DVD-ROM drive must be configured to do so. For information about how to configure your computer to start from the CD-ROM or DVD-ROM drive, see the documentation that is included with your computer, or contact your computer manufacturer.
5. After Setup starts, press ENTER to continue the setup process.
6. Press ENTER to select the option To set up Windows now, press ENTER. Do not select the Recovery Console option.
7. Press F8 to accept the licensing agreement.
Setup searches for previous installations of Windows.
* If Setup does not find a previous installation of Windows Server 2003, you might have a hardware failure.
Hardware failures are beyond the scope of this article. See a computer hardware specialist for more help or try the Hardware troubleshooter. For more information about the Hardware Troubleshooter, see the Windows Server 2003 Help topic "Using Troubleshooters."
* If Setup does find a previous installation of Windows Server 2003, you may receive the following message:
If one of the following Windows Server 2003 installations is damaged, setup can try to repair it. Use the up and down arrows to select an installation. To repair the selected installation, press R. To continue without repairing, press ESC.
Select the appropriate Windows Server 2003 operating system installation, and then press R to try to repair it.
* Follow the on-screen instructions to repair the installation.
Notes
o You might have to change the boot drive sequence in your BIOS settings to successfully start your computer from the Windows Server 2003 CD. Contact the manufacturer of your computer, or see your manufacturer's documentation, for more information.
o If you cannot start your computer from the Windows Server 2003 CD, you might have a CD-ROM or DVD-ROM drive failure or other hardware failure.
o After you repair your Windows Server 2003, you may be required to reactivate your copy of Windows Server 2003.
Jan 22, 2010 | HP Compaq ProLiant ML110 G4 Server
Need to install second cd driver in desktop computer
It would be much simpler to remove your current CD-ROM drive, and install a CD/DVD-reader-writer combination drive.
1. Turn the computer off, and disconnect the AC power-cord.
2. Remove the side-panels from the case.
3. Disconnect the "power" and "data" cables from the back of the CD-ROM.
4. Remove the screws holding the current CD-ROM in position.
5. Slide the CD-ROM out the "front" of the case.
6. Slide the new device into place, until the face is "flush" with the front of the case.
7. Screw the device into position.
8. Connect the data and power cables.
9. Reconnect the AC power.
Windows will "find new hardware", and will adapt itself.
Dec 10, 2009 | Acer Computers & Internet
I'm putting cds into the drive but they won't run and when I go to 'My Computer' it's not showing the drive
Is it a new drive? Is the latest driver loaded for it? are the cables in correctly? are the jumpers set correctly? Is it recognized in the BIOS? If you answered YES to all but not even recognized in the BIOS then its the ribbon cable or the unit itself
Sep 17, 2009 | Compaq Presario 5000 PC Desktop
My lexmark all in one printer wont install since i got a new e machine computer--i tried the disk and it stops at drivers--tried to do by computer add a printer without disk and still doesnt work
If you connect and turn on the printer then turn on your computer it should start the found new hardware wizard. don't do anything until or IF it asks you to install the disc, the make sure you direct it to find the files under the correct drive letter which is usually "D" or "E" .Good luck, .Dana
Sep 07, 2009 | Lexmark OfficeCenter X3350 All-in-One...
Dvd disk drive not showing in my computer
Hi!
The chances are that the drivers for them got corrupted and you can install them fron your motherboard cd. To install them go to Control panel-> add new hardware-> search for new hardware-> if it shows up then its good else add them from the list. It will then install the drivers from your motherboard cd (the cd you got with your system or from the cd you got with your disk drive).
If this doesn't help then check for the connectors(going into disk drive from power supply and motherboard) by opening your pc.
Please rate the solution.
Thanks
Rylee
Feb 08, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
Pavilion 525C won't start
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Az.
Sep 23, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
Dell laptop DVD_Rom not detected
well evidently you have a software problem, otherwise your dvd unit is broken, but lets hope not and try this:
you surely have the recovery CD or DVD that comes with your laptop and if you are clueless at computers you have to play attention on the following:
first is to ensure your unit is working and tha can be done by booting from any bootable CD. Just enter the bios if necessary, set the machine to boot first from cd and next from hd... then start with any bootable disc that you know is working. Windows installing disc can be, laptop recovery can be too... if it works now you know the problem is on the operative system and you need to focus on that.
try going to systems properties, then go to the exclametory sign and go properties with right button, navigate that options and if you are shown, ensure to enable DMA access mode. If you cant do this, just uninstall that device by clicking on the right button and selecting unninstal... and then do the same with any devices related to cds and ide devices... finally reboot your system and let windows put all that bach in place.
If this doesnt help you you might need to reinstall OS, so either backup your files and restart using the cd that comes with your computer or get back with more precise information, because yours is a very generic problem and many things can cause that.
Nov 17, 2007 | Memorex CD 482E (CD-482E) CD-ROM Drive
Samsung TS-H542A DVD±RW Burner Logo
200 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
