I need a way to bypass the codes of my vcr cassettes in order to copy to dvd using a Sony DVD/VHS PLAYER.
  • 10,515 Answers
Hi Rbright34,
As such there is no way to bypass the codes of the VCR.
I know it's frustrating as you might have heard different stories all across the real and outer ( Internet ) world.But that's the hard core fact.
I hope you have got a precise answer.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 12, 2009
DVD and VHS don't work
The outputs of your VCR/DVD player should be plugged into the audio and video inputs of your TV.
Mar 09, 2014 | Sony BRAVIA KDL-46W3000 Television
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Our Samsung DVD V6500 dual deck will copy from DVD to VHS, but we don't know how to reverse it so that we can record old VHS movies onto DVD.
the samsung dvd v6500 does not copy from vcr to dvd. in order to do this you will need to purchase a dvd burner and hook it up to your v6500
best of luck
merry christmas
Dec 07, 2010 | Samsung Televison & Video
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
Dvd/cd player Video Cassette player
try cleaning your video head, use a VHS tape cleaner.. use a wet type cleaner
May 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
