Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
My pc is new but slow??HELP
I use my pc for work..its a pentium 4 Intel celeron 2.4 dual core pci expresss with motherboard ASUS p5sd2-vm..its very slow and im not sure wat i can do at a low cost!!!
  • 2 more comments
  • gdcroft May 11, 2010
    What operating system are you using? If it's XP you can left click on "start" then "run" and type msconfig in the pop-up box and hit ok. The system configuration utility box will pop up. Hit the startup tab along the top. This will list all of the programs that get started when you boot the computer. You can turn these off by un-checking the boxes. When you un-check a box the program is not deleted, it just not started up every time you boot. You can still start up the program manually if you need it. I usually run with a minimum number of programs checked. The computer will boot faster and run faster because it's not tying up a bunch of resources on these programs you don't need. You will need to hit ok after making your selections and then you will need to re-boot. On the first boot up after the changes are made a window will pop up warning you that you've customized your startup configuration. Just check the box so it won't show you that message again and hit ok.
  • Carolyn Attaway May 11, 2010
    Do you have Norton or McAfee?  If so, that is what is causing it.
  • Frank Zhang
    Frank Zhang May 11, 2010
    when it happen running slow? or any new installation soft/hardware before slow appear?
  • Jerry Naidoo May 11, 2010
    How much of RAM do you have ?
    President:
  • ASUS Master
  • 1,996 Answers
Max out the ram, if possible, or at least increase it to 1Gb or better.(Go to crucial.com to use their scanner or memory advisor to see what's possible for your system.) Make sure virtual memory &/or swap files are set up correctly. Use the system configuration utility to see what's running at every startup, and use the task manager to see what processes are running in the background.
Minimize the number of applications that run at startup, deselect unnecessary services and avoid security suites and other AV programs that may be resource hogs, sticking with reliable but lighter apps like Eset's NOD32, etc.
You don't mention whether you're on xp or vista, but go to MS's help and how-to site and search performance for your OS, and you'll get access to a wealth of information about how to tweak your setup to make the most of it's ram.
If you set it up correctly, take out the trash, (keep temp files from growing too large, etc), keep it defragged, and minimize the number of nonessential programs installed into memory, you'll have plenty of speed to keep things humming along.
See useful links here and here and here and here for xp or here for vista
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 12, 2009
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000341
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Is intel e5800 processor 3.20 ghz is compatible with asus P5G41c-M LX asus motherboard thnks
Your motherboard is compatible with the e5800 processor.
It has Intel® Socket 775 and it will support processor listed below
1. Core™2 Quad.
2. Core™2 Duo.
3. Pentium® dual-core.
4. Celeron® dual-core .
5. Celeron® Processors
Thanks for using FixYa.
May 15, 2011 | Computers & Internet
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
Dec 15, 2010 | Intel D945GCCR Motherboard
Overclocking with p5sd2-vm motherboard.
i have no install the sound driver please help to the install...............
Jul 27, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
Support
ecs_buttom_03.gif LGA775 socket for latest Intel® Core™ 2 Duo / Pentium® Dual Core/ Pentium® D / Pentium® 4 / Celeron 4xx series/ Celeron® D processor ecs_buttom_03.gif FSB 1066/800/533 MHz
The above information was taken from their website.
Jul 06, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Intel processor E2200 LGA775 not working
This motherboard supports Intel single core Pentium 4/ Celeron processors, according to the asus website.
So your dual core is not supported.
You need to get a intel pentium 4 or celeron processor
Apr 04, 2008 | ASUS P5RD1-VM Motherboard
D345AJ
Not sure what information you were requesting. So here is some information about your motherboard:
- LGA775 socket for Intel® Core2 Duo/65nm Pentium D/Pentium 4/Celeron CPU
- Intel 865G + Intel ICH5
- 1066(O.C)/800/533 MHz
- Dual-channel DDR400
- Intel® Extreme Graphics 2
- 1 x AGP 8X
- 2 *ATA133 ,2 x SATA
- 10/100/1000 LAN
- 6-Channel audio
Here is a link to all the drivers to your motherboard:
This includes the manual!
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
If you need more help Let me know. :]
Dec 10, 2007 | ASUS P5PE-VM Motherboard
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
