Question about HP LaserJet 8150n Printer
50.1 fuser error
I have the hp 8150n printer. it has on the screen "50.1 fuser error". please advise. thnx
  • 150 Answers
Fuser error is the high voltage drum. Normally there is a blown fuse somewhere attached to it that gives the error other you could have a defective fuser unit. Dont attemt yourself it works with very high voltages +- 600V
Posted on May 12, 2009
    Sniper:
  • 87 Answers
Please change the fusing assembly.
Following is the part no.:
C4265-69007 Fusing assembly - For 220 VAC to 240 VAC operation - Bonds toner to paper with heat
This would solve the problem.
Posted on Jun 17, 2009
50 fuser error
Pl replace fuser asembly, no repair advisable for this issue..
Feb 04, 2012 | HP Laserjet M1319F Laser Multifunction...
We have a HP 8150N. The printer will not print and is giving a 62.0 printer error message. We have turned the printer on and off which has not helped. Is there an eazy fix?
62.0 memory error. This error indicates that the memory that is soldered to the formatter is likely bad. If the error was 62.1 or 62.2 that would indicate that the memory in one of the upgrade slots was bad. The only real solution to 62.0 will be to replace the formatter.
Jun 13, 2011 | HP LaserJet 8150n Printer
HP Laserjet 8150N User Error 50.1
The 50.1 error is caused by the fuser assembly not getting hot. The part you need is called a maintenance kit, it comes with the fuser and all of the pickup rollers needed to keep the printer in good shape. We have the kits available for $125 plus shipping. You can contact us at 318-447-9040 or at tech@ccl-la.com if you need to place an order. The kit will also include a PDF version of the service manual for this printer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP LaserJet 8150n Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Mar 18, 2008 | Computers & Internet
HP LaserJet 8150n Printer Logo
302 people viewed this question
Seeker5211
Seeker5211
