Question about Toshiba 42H81 42" Rear Projection Television
Wavy picture except when displaying a 1080p image
I've had my 42H81 for 5 years. Starting two years ago the picture started getting wavy. I had a service technician come out and he replaced the digital convergence unit. The tv was fine for about six months and then it started having a wavy picture when first turned on; after about 10 minutes the picture would be fine. But it's gotten worse over time. Right now, I can view a 1080p image from my cable box attached to a color stream input without any problem. Video from all other inputs, VCR, DVD, regular cable, antena all display a wavy screen. When i set my cable box to a 480 or 720 resolution it displays a wavy screen. I went into service mode to see if I could adjust the convergence. It displays a narrow band at the bottom of the screen fine but the rest of the screen is wavy. If I go to the color stream input my cable box is on (1080p) the convergence screen is perfect. I've read the posts for wavy screens and they point to replacing the STK392-110 convergence chips and 1.8 ohm resistors.  Is replacing the STK392-110 covergence chips a solution for this problem or does the problem lie elsewhere?
  • Anonymous Dec 13, 2007
    I have exactly the same problem. After 10-15 minutes of warm up time it goes away and is fine. You say the hyperboard needs to be replaced, how much would a repair like that typically run, and is it something I could repair myself? Im moderately skilled at fixing small electronics, but have never tried on something like a tv.
    Genius:
  • 1,694 Answers
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Posted on Nov 23, 2007
SOURCE:
Panasonic pt-50lc13 small wavy lines
Look to see if it happens on the rear audio and video inputs--that will narrow down where the problem is.
Be aware this model was RECALLED and all original owners were supposed to have the set replaced a few years ago.
Also rule out the signal---if using a cable box connect the cable without it directly to the coax fitting---box can cause this---stranger things have happened.
May 27, 2012 | Panasonic Televison & Video
Wavy distortion of the pictures
Hello!
That can be repaired, the vertical and the horizontal that regulate the voltage towards the projection maybe lessen or fulty. you can let the service man/service center repair this. these not much cost you, that is very cheap part and a minimum labor cost.
melnavz
Mar 17, 2008 | Toshiba 50H82 50" Rear Projection...
When you turn on the the TV the picture is good with in a minute or so the Picture turns wavy and has a double image. I can turn it off, then turn it right back on the picture is good for any where a...
The problem with the television is the lamp. It is faulty that is why the screen turns wavy in minutes.
The solution to that is to replace the light and your television will be in good condition once again.
Take care
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
57"H82 Toshiba-- wavy picture
you got somes capacitor bothering you, and nop, there are nothing you can do, but call a tech, the problem could be in the video card or in the power supply but is a tech job....good luck
Aug 08, 2006 | Toshiba 65H82 65" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
538 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
