I have an "In-Focus" LP-130 DLP Projector which is giving me some problems. When connected to any computer and attempt to play any video,it has a bunch of horizontal lines resembling a barcode running horizontally across image. What is the problem? Any help would be very much appreciated.Thank you. AL
  • mayan38 May 12, 2009
    Hello Zohail. thank you very much for your help!! It was in fact the cord. I changed it and the lines were gone! You are a lifesaver my friend! Thank you!
    It was very helpful.It solved my problem! Thank you very much!!
    President:
  • 1,223 Answers
Pls reply that if these lines also comes in other soorces other than pc as dvd player or thru any other input mode , have u changed the vga cable u are using and try
Posted on May 12, 2009
How do I connect my LP130 to RCA video. What type of converter do I need?
You need CSV to RCA or CSV to S-video cable.
http://www.itsupply.com.au/products/warranty/infocus/cable-csv-to-rca-2m/product_info.php/cPath/1943_2629/products_id/65008
Sep 18, 2013 | InFocus LP 130 Multimedia Projector
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Feb 19, 2012 | InFocus LP530V Video Projector 2000 ANSI...
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
May 21, 2011 | InFocus LP530V Video Projector 2000 ANSI...
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
Hi my name is Vortash the bars you are seeing are the result of a capacitor or diode failure in the projector possibly in the power supply , they are usually referred to as ac hum bars .. this is where a circuit that should be running on pure dc voltage is being tainted by ac seepage from another part of the machine .. its also possible with the heat generated in these units it is just bad solder or dry joints ,,, best get an engineer to check it though as ot may damage the bulb and I would bet money on a repair being cheaper than a replacement bulb hoe this helps regards Vortash
May 12, 2009 | InFocus Office Equipment & Supplies
DLP Infocus Problem
first of all, the infocus lp 790 is an lcd projector, not a dlp. second, the light filter in front of one of the lcd panels is burnt, and unfortunately cannot be purchased separately.
May 11, 2009 | ASK Proxima InFocus LP790 and Proxima...
LP 130 PROJECTOR SCREEN IS GREEN WHEN I HOOK UP DVD WITH COMPONE
the cable might be the problem. swap out with another cable. other than that, make sure that the correct input is selected and the resolution matches.
Mar 11, 2009 | InFocus LP 130 Multimedia Projector
Remove the top cover?
Hi amp422
At the bottom and on the sides of the Projector there should be screws that can be taken out.
Unscrew these and you should be able to open up the unit.
May 01, 2008 | InFocus LP530V Video Projector 2000 ANSI...
116 people viewed this question
k24674
jasbo
jasbo
