Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic PT-53wx42 has a greenish/yellow tint to it.
I recently noticed the picute on my Panasonic PT-53wx42 has a greenish/yellow tint to it.  It's hard to describe - the whites just don't look crisp anymore.  Any idea what the problem could be.  The set is about 5 years old.
    Problem Solver:
  • 10 Answers
It may just require an advanced calibration. I had the same problem out of the box. Everything had a "Matrix-like" look to it. I had a television repairman come in and at that time I watched him fumble through the "other" manual for the T.V. which only the servicemen have access to. Of most importance was the sequence of codes he had to enter to access the professional calibration menu. It went something like turn it on CH124, put the sleep timer on 30mins, push vol down twice on the set, then push menu. I googled for the code sequence some time ago and had found it then. I would try this route before you attempt to take the screwdriver to it. Good luck.
Posted on Jan 20, 2008
  • 579 Answers
Trty re-soldering the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Posted on Jan 02, 2008
Sony rear projection tv has green tint
The model number is not a sony, what is the model number on the back if it is Sony?
Nov 02, 2011 | Panasonic PT-53WX42 53" Rear Projection...
I am using Kodak Photo Paper and get a distinct greenish tinge. Have recently replaced the yellow cartridge. Why the tinge?
ive been printing photos on my new epson and im noticing the same thing i tired a different brand of paper (the dollar store kind) and there seems to be no greenish tint, im wondering if its actually the kodak paper itself i thought it might be the printer but the blacks on this other paper seem to be dead on. i also tried some hp paper in a 5x7 format insted of 4x6 and i didn't notice the greeny tint so my assumption is its the paper.
Mar 27, 2010 | Canon BubbleJet i560 InkJet Printer
Large fish eyed picture
TRY NEW CONNECTIONS AND JACKS ,,ALSO IN THE MENU GO TO COLOR CONVERSION AND USE IT
Apr 19, 2009 | Panasonic PT-52LCX65 44" HDTV
Yellow coloring on Panasonic TV
IN THE MENU FIND COLOR CONVERGENCE TO FIX THAT
Nov 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic red and blue picute
you need to replace both the convergence Ics they are STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions. heres the link.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT-53WX42
Need to replace the convergence amps and any 2.2 ohm resistors in the return. That unit takes two STK392-110 Sanyo amps - but for greater reliability use STK392-150's and get them, from some place like ACME to be insured their not chineese knock-offs..
Bill
Apr 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
My darks are to dark on TV
what happens if you adjust the contrast or brightness?
Feb 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-50LC14 LCD rear projection
well it gets real compicated, if you are good with electronics and can take apart and put back together the inside the projector needs cleaned or the easy fix replace light engine about $600.00 rebuilt
Oct 07, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
