Question about Pioneer DEH-P4100
"Down volume" button on Pioneer head unit in my '05 Scion broken
I have a Pioneer factory head unit in my '05 Scion xB. The "volume down" button stopped working out of the blue. Nothing has been spilled on it, all other buttons work. Any ideas?
  • eprice May 12, 2009
    i guess my switch needs to be fixed, then. no clicking...
    thanks very much for your help!
  • eprice May 18, 2009
    thank you, mcj78 – i was thinking about doing that but didn't want to take it all apart if it was pointless. now i know someone else has done it with success, i'm more inclined.
    i checked a junkyard to see about replacing the unit and they said the part would be $290. not really an option at the moment, so i think i'll try taking mine apart instead.
I had a similar problem with one of the cursor type keys - I ended up taking the face apart (4 small screws on the back then gently prise apart) & discovered the small pin attached to the back of the button which presses the internal switch had slipped off the pad, it took a couple off attempts to put it back together again but once it was re-assembled it was fine, just be careful not to lose anything! ;)
Posted on May 15, 2009
  • mcj78 May 18, 2009
    No problem, everything will only go back in place 1 way - try and remember how it looks once you take the back off (it's easiest if you have the panel face-down as the buttons can't fall out that way!) then once you take the circut board bit off try pressing all the contact points (they're little white buttons) to see if they click when pressed - hopefully it'll be the same problem as I had where it was simply misaligned!
  • 150 Answers
Listen for click sound , the volume up will have it , if the vol down does not then you have a faulty button (internal tactile switch) which needs to be replaced. If you can hear the click then there is a communiction error between then button and the microprocessor which also needs to be taken in for a checkup.
Posted on May 12, 2009
When my radio does this it is the same make I unhook the power to it by unhooking the battery it resets the radio but then you need to set the clock my problem
Posted on Dec 10, 2010
How do you fix a stuck down volume button on car stereo?
have radio removed by a car stero shop, could be a broken button
Aug 21, 2014 | 2005 Scion xB
How do you fix a stuck volume button on scion xb stock stereo?
The only way to fix it is to take it apart and see if it is just jammed or if the button is defective if defective you neeed to replace it they are very small so you need some good soldering skills. Hope this helps.
Aug 21, 2014 | Pioneer 2005-2006 Scion Tc Xa Xb Cd Mp3...
I have a 2005 Scion XB radio system. The volume down button is stuck in and won't work. I tried to ''pry'' around it to try to free it, but it's like there is a spring inside that is missing. How do I...
Take the radio out and remove the faceplate. Spray a little wd40 on a cloth and wipe down the inside of the faceplate. Worked for us like a charm.
Mar 08, 2010 | Pioneer Car Audio & Video
I have a 2005 scion xb with 30000miles and the vsc and check ligh
I have a 05 Scion XB W/215000 mi My vsc ck eng light go on all the time. The dealer told me it was a little dirt speck of dirt in the timing gear and it would cost almost a thousand dollars to fix it. So I just disconnect the neg battery cable for 2 minutes and reconnect. The light stays out for about 4-6 months. when it comes on again I just repeat the steps.
Jan 14, 2010 | 2005 Scion xB
My radio volume wont go down
Pull the fuse and let it reset itself.
Jul 03, 2009 | 2004 Scion xB
Does my stock pioneer stereo in my 05 xb have an ipod adapter
No i have pulled out the stereo myself and there is no port for it, that option is now offered on the 2008 which sucks because they where giving ipods away at the dealership when i got my 05 Scion xb makes no sense huh.
Jun 08, 2009 | 2005 Scion xB
Best buy soild me a head unit pioneer avh p5100 dvd need to unlock code for dvd player for scion 06 xb
the unlock code should be in the hand book if not you can get it from best buy
May 02, 2009 | Car Audio & Video
Scion xa radio - T1805 volume button stuck
I have a 2005 Scion XB radio system. The volume down button is stuck in and won't work. I tried to "pry" around it to try to free it, but it's like there is a spring inside that is missing. How do I repair this.
Thanks in advance for your help!
Apr 20, 2009 | Pioneer Car Audio & Video
2005 scion xb Stereo problem
If the Stereo Got wet, The first thing that will stop is the Internal Amplifier. On these Pioneer Stereo's the Only thing that You can do is Replace the Head Unit. Please Rate My Response! Thanks!
Jan 31, 2009 | 2005 Scion xB
Pioneer DEH-P4100 Logo
304 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
