Question about Miele S318 Bagged Canister Vacuum
Miele vacuum turbo plus brush does not rotate
The turbo plus brush is not rotating. I have checked the hose and cleaned the brush attachment (taken it apart and cleaned it) but the brush is not moving when I turn the vacuum on.
  • jeanakemi10 May 12, 2009
    I have turned the vacuum on but the turbo brush still does not rotate. Originally, when I turn the vacuum on, the brush would be turning because the air is making it move. Can the belt become stretched out with age (I think my unit is about almost 10 years old)?
    Hopefully, the replacement will solve the problem. Thank you for your quick responses.
  • 10,515 Answers
Hi Jeanakemi10,
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
I hope this would help you ti fix the concern.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 12, 2009
  • taran_2005
    taran_2005 May 12, 2009
    Read
    http://www.ehow.com/how_112391_fix-vacuu...
    More likely, replace the belt and the issue would be resolved.
    thanks.
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
Miele vacuum
Check the end caps on the brush roller they might have collection of dirt build up also the unit nust be assembled correctly with no air leakage by the fan so the suction can spin the fan
thiis turbl is made by wessell for Miele the replacement is just as good under their brand for a lot less money
miele turbo nozzle carpet and bare floor brush
Jul 02, 2016 | Miele Vacuums
Why does the brush continue to rotate on bare floor setting as well as using hose attachments?
Hello! The brush roll shut-off feature is on select models. Your vacuum may or may not have this feature. If it does not, the brushes will continue to rotate while hose is removed or in use and at all times while cleaner is on. The vacuum must be in the upright position to lift rotation brush off the carpet when cleaning above the floor. Be sure the vacuum does not tilt forward when doing above floor cleaning. Hope this was helpful!
Aug 10, 2014 | Dirt Devil Vacuums
Miele turbo s514 power
If it has no suction take bottom peice off take out brush roll then run clothes hanger through dust channel to clear any blockage if none there its in your hose
Mar 27, 2013 | Miele S514 Solaris Turbo Plus Vacuum
Can the Turbo Brush on a Bissell vacuum be repaired?
Hey Teri! If you have good suction from the end of the upholstery hose, the turbobrush should rotate as long as there isn't anything binding the brush. Otherwise, a new turbobrush will need to be purchased.
Here's a quick link to ordering one online.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2433&st=2&cid=ccsocial
Feb 02, 2013 | Vacuums
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
This vacuum is not picking up anymore when used as an upright, however it does still work very well when using the hose and attachments, I have looked at the vacuum but I cannot figure out where the clog...
Is the brush rotating?
Have you turned it over, taken off the bottom plate and cleaned it out?
Is the belt in good shape or does it no longer rotate the brush?
Is it on the proper floor/carpet setting for the surface you are cleaning?
Try these as they usually repair most vacuum issues of this type.
Apr 15, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have an old fantom thunder upright and need to take the bottom off it to see what is stuck in it. I don't know how to do this.
moz-screenshot.jpgI found a manual for the Fantom Stick Vac, model FS801 (your model may be different).
For "Cleaning Air Driven Turbo Brush", it says:
  1. Remove the turbo brush from the hose or extension tube.
  2. Slide locking latch forward, then tilt the top housing of the brush upwards. The top housing is hinged and will tilt up approximately 45 degrees only.
  3. There may be some dust, lint, hair, etc. on the turbine wheel. Remove as much of this as possible.
  4. You may also use the unit's hose with the crevice tool attached, and use the vacuum to remove any additional debris from the turbine.
  5. Ensure that the turbine wheel moves freely by rotating it with your finger. If the turbine does not rotate, call Customer Service for help.
  6. Once clean, close the top cover of the turbo brush and slide the locking latch towards the rear of the brush to lock.
There is also an image in the manual that might help. You can download the manual for free here.
Hope this helps!
Mar 03, 2011 | Vacuums
Brush is not spinning
Usually, this is caused by the brush assembly end bearings becoming bound up with string, thread, and hair. Remove the brush and clean the bearings and end shafts. Oil them lightly with 3-1 oil or similar. Check the condition of the drive belt and replace it if badly worn or broken. Check the rotation of the brush by hand before installing the belt. Hope this helps!
Oct 04, 2010 | Miele Powerhouse Plus Bagged Upright...
How do I open the Turbobrush attachment on my Miele vacuum?
Loosen& remove 4 screws at bottomof turbo brush After cuttingventangledthreadvthrough crosswise with sissors. Turn turbo brush over gentlyon an even surface. Carefully separate and liftvoff upper casing. Then remove stuck threads.reassemble lift upper casingto bottom plateand pressinto place.turn unit over topside down and replace screws.
Jul 04, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele S318 Bagged Canister Vacuum Logo
620 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
