Question about HP PSC 1610 All-In-One InkJet Printer
HP 1610 (all in one) not responding
The 1610 printer says ready on the screen..I give it a printer command and the printer turns on, a paper advaces half way into the feed and stops..No printer icon in the lower right hidden tool bar..Eventually, it spits out the paper with one line of "gobbley goop"!..When I make the printer test with the printer keyboard, it prints the test OK!..any idea what's wrong?..Jim
  • HP Master
  • 2,794 Answers
Re: HP 1610 (all in one) not responding
HP has software that will detect your driver and update if necessary. You should go to their website and download it.
Posted on Jun 22, 2008
  • 55 Answers
Sounds like a bad or outdated driver. I would remove the printer and have windows either scan for it automatically or download a new one from the manufacturer website.
Posted on Oct 23, 2007
0 characters
3 Points
Hp laserjet 1132 mfp paper pickup issue E1 error
First I would try a "heaver" weight paper in place of your current paper.
Second I would look for something blocking the paper path...maybe a piece of paper got stuck.
Hope this helps...
Here is the link to the manual from HP:
Jan 12, 2016 | HP Printers & Copiers
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
All of the sudden, constant paper jams & no paper signal when ful
You can clean them from the rear access/jam cover. Just be careful when turning the rollers, must be slow and smooth movement.
Aug 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp 1610 keeps saying out of paper
Just try to pull the paper fully upto end in the paper tray if it is not accepting thn u have to clean its sensor clean it pad and roller.
Jul 27, 2009 | HP PSC 1610 All-In-One InkJet Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Paper feed problem & out of paper error come on.
the gears which pull the papers are worn out.and its the time now the gears to be replaced.or any object is blocking that gear to move this is the time for servicing.
Aug 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
110 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
