Question about Panasonic DMR-E85H DVD Recorder
Trouble with remote
For some reason my remote isn't working. It says "set 1" every time I press any button on my remote. Tried unplugging it, changing batteries.
  • 1 more comment
  • claymoney Oct 28, 2007
    Thanks, I pushed 'enter and 1' simultaneously, and it fixed my problem. THANKS A LOT!!!
  • dabears Nov 15, 2007
    my dvd/vcr player is saying set 1
  • Anonymous Dec 14, 2007
    Please change the disc.
Plese change the disc
Posted on Dec 14, 2007
    Problem Solver:
  • 6 Answers
Remote can be switched to control more than 1 recorder, on the remote press enter and1 simultaneously for 4-5 secs, this should switch remote to control dvd1.
Posted on Oct 27, 2007
This happened to me twice before, I forgot the solution but it's in the owners manual, if you dont have it, go view it on pansonic's site.
My Bell remote has been working fine since I had Bell and the remote isn't working like when I press any button on the remote the light on the remote goes red and red for a long long time I tried
1) clean the c.batteries with c. cleaner
2) retight the spring contacts batteries with long pliers for better contacts
3) open the remote control and clean the keypads for: dirty, corrosion, oxide, and bad contacts.
4) reset the code again.
5) try again.
6) if the problem persist, problem with the Syscon, you must go to repair shop for fix it.
God bless you
Oct 16, 2012 | Bell Televison & Video
Umm my tv2 remote isn't connecting to my reciever so i tried to change the remote address and it doesn't work
Hi my nameis Mike Houston of DISH Network and I see your TV2 remote isn't connecting toyour receiver. You will want to make sure you're at the TV1 location to programthe remote for TV2, press the Menu button 2 times and you will see the SystemInfo screen. On the bottom for the screen you will see the remote address forTV2, make sure the TV2 remote has fresh batteries inside. On the back of thereceiver their will be a Remote Antenna port and you want to make sure that ishand tight. Push and release the SAT button and press record and you should seethe address change for TV2. I will send a link to help with these steps; http://www.dishnetwork.com/SupportSection/remote-control.
Jul 30, 2011 | DISH Network 322 DTV Receiver
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
My remote suddenly stopped working.
If you're seeing on the LCD of the DVD player something like "DVD1" every time you press a button on the remote, try this: Change the command mode of the remote to match the player. Do that by holding down the Enter key on the remote and pressing the respective number. In my example above, hold Enter and press button 1 to set the command mode of the remote to DVD1. I had this problem and even unplugging the player didn't help, but the above worked for me.
Jul 16, 2009 | Sony RDR-VXD655 Recorder
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
Remote control does not work at all.
The winner is....
SET 1 on the console; press and hold the ENTER button down and while holding Enter; press and hold "1" button for about ten seconds together. Your remote and console should be in sync again and try cutting off the dvd recorder with the remote and it should work.
THIS WORKED FOR ME!!!!
THANKS!
Feb 18, 2008 | Panasonic DMR-ES35VS
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Panasonic DMR-E85H DVD Recorder Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
