Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
How do I change the pulley on a Whirlpool wash. mach. H2O pump?
I bought a new water pump #285317, it came with a "V" belt pulley intalled, and a serpentine pulley on the side. Now, How do I remove the installed pulley to use the serpentine one?
Thanks to all.
I figured out that the pulleys screw on/off.
Posted on May 13, 2009
I have a whirlpool ultimate care ii heavy duty super capacity plus washer that fills, and agitates, but will not "spin" or drain water. What do you guys think needs replaced?
"If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it."
May 04, 2015 | Whirlpool Washing Machines
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Squeak is annoying the only parts not change yet is h2o pump ac bearing and p/s bearings dont know what to do
Remove the belt and turn the water pump, A/C clutch and power steering by hand in the direction they normally rotate. You may be able to feel a bad bearing. Does the sound change when you turn on the A/C or Defrost? That would point to the A/C clutch.
I assume you have already tried a new belt, and have cleaned all the pulleys to make sure there isn't something on them causing the belt to slip (then squeak when it catches again).
Oct 29, 2010 | GMC Sierra 1500 Cars & Trucks
New Problem
remove drain pipe and make sure it is not blocked i had same problem And found money in the elbow of drain pipe blocking it up. when u r trying to turn by hand u are turning gearbox as well and is normally not easy to spin when they stop during a cycle
good luck
a very helpful rating is appreciated for answering ur query....
Aug 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer water won't drain out
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washing machine stops after wash cycle. Will not drain for rinse cycle
Check the following to address this issue. if all checks out ok, replace the timer/control.
1. Clogged drain line or water pump
2. Water Pump
Jun 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
A/c and power streering belt how do I intall i think im missing
here is the diagram for your car. I hope this helps.
Apr 10, 2009 | 2000 Hyundai Accent
My washer doesnt wanna spin
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jul 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Doesn't Spin!
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
79 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
