Question about GE Nautilus 24" Built-in Dishwasher
Water not draining completely from Dishwasher tub
Hello, Water is not completly draining from dish washer tub. So after the dishwasher ran still there is water in the tub and I can hear water draining to sink when during running cycles
  • GE Master
  • 19,396 Answers
That usually happens because of a faulty water level sensor, check it out.
Posted on May 21, 2009
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
How to remove debris from the drain holes at the bottom of the dishwasher tub, which is preventing the tub from draining all of the water completely?
I had a similar problem when my dishwasher wouldn't drain and was causing the kitchen sink to back up. I poured a little drain cleaner in the bottom of the tub (where the drain holes are) and let it stand for about 15 minutes then ran a hot rinse cycle (don't put any dishes in the dishwasher while you're doing any of this). The water still hadn't all drained but after a day or two of not using the dishwasher it drained on it's own and hasn't had any problems since. I would recommend reading your manual to make sure that using drain cleaner doesn't void any warranty you may have. Also, it's a good idea to do an empty rinse cycle at least once so that there's no chemicals getting on your dishes.
Aug 23, 2010 | Dishwashers
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher didn't drain completely after final rinse.
Check the drain hose stub connection at the disposal for plugging. Lots of material flying around in there which could block the stub pipe. You might consider inserting a short section of drain pipe that has a built-in stub into the regular sink drain and plug the disposal stub. Also check the screen at the bottom of the lower spray arm assembly for plugging. Clean the screen in a mixture of hot water/detergent/white vinegar for an hour or so. That will remove hard water deposits from the screen as well as any food debris. The draining process is a timed event, so it depends on fairly rapid removal of the water. Hope some of this helps!
Mar 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jan 31, 2009 | Caloric 24 in. CDU510C Built-in Dishwasher
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Monogram Won't Drain completely
the drain was clogged. A handyman used a snake to clean it out.
Apr 04, 2008 | GE 24 in. Monogram ZBD6880KSS Stainless...
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
690 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
