Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
When I try to make a cup of espresso with my Saeco Royal Professional, water comes out of the hot water/steam nozzle instead of the coffee output. It also is making a high pitch noise.
    President:
  • 1,618 Answers
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
Posted on May 14, 2009
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
Mar 30, 2009 | Saeco Royal Professional Espresso Machine
How to purge saeco royal digital plus
run hot water from the steam nozzle for few seconds
Mar 01, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital not providing water
If you try to make a cup of water, can you make a full cup or just a half?
Jul 31, 2008 | Saeco Royal Digital Espresso & Coffee...
Saeco royal cappuchino ventilate
Alternatively, try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Jun 30, 2008 | Saeco Royal Professional Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
204 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
