Question about Dryers
GE Dryer won't stay running
My mom's GE dryer will start and heat only if you hold the start knob.  I bypassed the start switch and the dryer runs and heats through the cycle normally.  A new start switch did not fix the problem.  Any ideas?  This is a recent model unit and is fairly basic in features.
    Top Expert:
  • Dryers Master
  • 47,257 Answers
The door latch could be defective. The dryer will not start unless it senses that the door is latched (not just closed).
Posted on Feb 01, 2018
gittos73
  • 244 Answers
SOURCE: No Heat
more than likely that u have blown heater element u can test your element with a power cord connect it to the live earth and neutral and plug it in and element should heat up if not it will be your element that has blown
Posted on Aug 11, 2007
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
  • 163 Answers
SOURCE: estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
hektor1961
  • 70 Answers
SOURCE: GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Aug 17, 2009
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't hold run position
Most likely problem is a bad door switch. This is a common problem. Another possibility is a bad timer switch.
Jan 14, 2012 | GE DPSR483EA Electric Dryer
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
Will not stay on. if you hold knob it will go but will not stay on automatically
heatman101
Jul 28, 2011 | GE DBSR453EBWW Electric Dryer
I HAVE A GE DRYER DBXR453GA2WW. We replaced the belt. The start knob is missing but we can still get it turn on by manual turning the apparatus underneath the knob. However, the dryer will not stay on.
If the dryer starts but will not stay running, the cientrifugal switch in the motor is likely faulty. The motor will probably need to be replaced.
Kelly
Mar 24, 2011 | GE Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
GE Dryer timer stoped working and so it runs and runs
Dryer knob assembly unit is faulty and loss of heat sounds like an element going out.
Dec 10, 2008 | GE DBSR453EBWW Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
308 people viewed this question
Top Dryers Experts
Marvin
Marvin
