White line on the middle of the screen
Mostly in the beginning while turning on TV, it would not get picture and only whte line in the middle of the screen but voice is coming. slowly, after 15 to 30 minutes, the picture comes. what is the problem ? and whether it can be solved by ourselves ?
  • 150 Answers
No you cannot solve this yourself unless you have a soldering iron with solder plus be able to identify dry joints or defective capacitors. Please take to a TV service centre.
Posted on May 12, 2009
How do I know where to hook wires p on model 621MM master mechanic door opener
Your wires should be color coded blk/ white & solid white you will have a pair for each sensor twist the white wires together and twist your blk/wh wires together now on the back of the opener you should have three screws connect whites to the middle screw a(2) and your blk/white to the third screw (3) your sensors should light up now u should have a solid whte and red/whte connect red/whte to #(1)screw and white to #(2) your wall button should be lite
Mar 06, 2015 | Sears Craftsman LiftMaster Chamberlain...
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the...
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2009 | Sony KP-53XBR45 53" Rear Projection...
TURN ON AND SCREEN IS BLACK W/ WHITE LINE IN MIDDLE
this might be the psp's problem you might of droped it .so go to a mechanic to help you pls. vote for me cloud_foe
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
I have a white Verticle line but I get a picture
Have you tried unplugging the sat receiver and plugging it back in? This will reset it.
Dec 21, 2008 | Sony KV-32XBR450 32" TV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
