Question about InFocus Office Equipment & Supplies
When connected to any computer and attempt to play any video,it has a bunch of horizontal lines resembling a barcode running horizontally across image.
I have an "In-Focus" LP-130 DLP Projector which is giving me some problems. When connected to any computer and attempt to play any video,it has a bunch of horizontal lines resembling a barcode running horizontally across image. What is the problem? Any help would be very much appreciated.Thank you. AL
  • 431 Answers
Hi my name is Vortash the bars you are seeing are the result of a capacitor or diode failure in the projector possibly in the power supply , they are usually referred to as ac hum bars .. this is where a circuit that should be running on pure dc voltage is being tainted by ac seepage from another part of the machine .. its also possible with the heat generated in these units it is just bad solder or dry joints ,,, best get an engineer to check it though as ot may damage the bulb and I would bet money on a repair being cheaper than a replacement bulb hoe this helps regards Vortash
Posted on May 17, 2009
How to fix horizontal lines appearing on my Samsung TV
its a screen fault
if lucky and you can get one
one of the electronic boards inside the TV needs replacing
Mar 07, 2017 | Samsung Televison & Video
GREY BANNED OUTPUT
It is symptom of dirty / clogged video head.
Please use good quality mini-dv video head cleaning tape to clean head. Problem will be resolved.
Mar 16, 2009 | Canon ZR850 Mini DV Digital Camcorder
Osprey-230 video capture card distorted
you must connect all cameras to solve this problem.if your capture card supports e.g. 4 cameras and you are only 1,2 or 3 connected the image can be poore.your video card has nothing to do with this.
Aug 28, 2008 | ViewCast Osprey-230 (OSPREY230) Video...
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Horizontal line throught the screen.
Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Nov 12, 2007 | Gateway FPD1975W 19" LCD Monitor
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
229 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
