Have a AS18U samsung spilt AC which is giving out very bad odour..
I have a AS18U samsung spilt AC which is giving out very bad odour..we cleaned the filters but nothing happened ...please help!
  • Anonymous Mar 30, 2014
    My hitachi ac is constantly giving out bad odour. Also, I find it has stopped draining out of water. Are these two problems linked?
  • 148 Answers
Just happened out of the blue or first time starting it this year
Posted on May 12, 2009
Renault grand scenic - ac smells damp and odour - like bacteria
This vehicle's ac system has a condensation drain. Have your mechanic check it for blockage. Quite common on all vehicles for this to happen. Once the blockage is cleaned, run the heat on high to dry the ductwork out. The odor should dissipate slowly.
Nov 12, 2013 | Renault 181 Cars & Trucks
Hi, I have a Goodman GMS80903BNA Furnace and recently what happens is that when the thermostat calls for heat the draft inducer motor starts. However, after this nothing seems to happen. I don't h
Youcould be loking at the pressure switch try jumping it out and see if it lights some times you can fool it in to working , check the hoses are tight and nor spilt or take a drill bit and just clean out the 2 ports where the hoses fit some times they get blocked , also check you air filter is clean and your fan
Dec 18, 2012 | Goodman GMS80903BNA Heater
Offensive odour
Have you tried cleaning out the filters? these get clogged up sometimes and if not maintained properly they can build up and release a pungent odour
Here is a video on youtube that wll help you if you do not know how to do this
http://www.youtube.com/watch?v=Q0TiugqnGbk
Aug 16, 2012 | Bosch Washing Machines
Smelly dishwasher and slow cycle
The fact your machine gives off an odour and a slow cycle seems to point to a blocked pump, Disconnect the machine from the main power supply, Remove the back and you will find the pump located at the bottom of the machine, Remove the large hose by squeezing together the retaining clip and you should find it is clogged. Clean all filters within the machine and it should clear the odour and help the machine to run better.
May 04, 2012 | Bosch 24 in. SHX46A05UC Built-In...
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Spilt drink over keyboard now most keys dont typee
Click Here!!
to see my step by step cleaning how to!!
As for cleaning a laptop computer keybord, I would use a can for compressed air, q-tips, and soapy water. I would be careful about getting the laptop too wet as water can seep into the computer. Hope this helps!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
May 07, 2010 | Samsung NC10-14ROBL Notebook
Odour filter
hi there patrick the odour filter is located under passenger footwell you will need to remove cover (if fitted) unhook fusebox from bracket remove bracket once moved you will see a cover beside heater now you will need to remove three 7mm screws once thats done remove cover remove filter & fit new one once thats done rebuild back up hope this helps you.
Jan 19, 2009 | 2000 Ford Focus
A/C Samsung spilt ( working fine then after 8 hours gives warm air)
It sounds to me like your fan cycling switch is sticking while the unit is cycling off (fans). When this happens your condenser does not have the ability to remove the heat from the refrigerant which in turn causes the compressor to load heavy. This creates a very high pressure condition on the high side. When this happens go outside and see if the condenser fans are running.
Hope this helps You
please rate me
Jul 18, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
