Question about Rainbow E series Canister Wet/Dry Vacuum
How to operate the shampooer on my rainbow e series
How do i operate the shampooer on my rainbow e series, how much water do i put in the basin and how does it work
  • 25 Answers
SOURCE: Rainbow E series Canister shampooer
e series aqua mates do not use a pump only pressure from water supply <faucet> if no water is getting through the valve assembly is probably bad. which has no servicable parts, reccomend taking to local vac shop to replace valve assebly in handle. not an easy job and can damage more if you attemp to fix. rainbow parts not cheep so dont want to break more than need to.
Posted on Mar 26, 2008
  • 198 Answers
SOURCE: rainbow e2 aquamate
chk out the screw nut assembly at the bottom of the basin....may be its nt takin the total pressure
Posted on May 26, 2008
IrishDruid
  • 2712 Answers
SOURCE: rainbow e series
If you have the Rainbow e series, then this manual will explain exactly how to remove the separator from the wash basin and the basin from the caddy. (Please refer to page 6)
http://www.rainbowsystem.com/pdf/manuals/rainbow_eseries/eseries.pdf A special tool is stored on the underside of the power unit next to the separator , which you can use to loosen the brass nut holding the separator.
The manual also provides instructions on how to remove the basin and clean it.
In my opinion, it is most likely a blockage in the tubes that must be causing this problem. This seems to be a common issue with this cleaner. There is also a small metal ring between the separator and basin that may be dislodged and causing this problem. Please the manual for an idea of what I am talking about.
If that does not help, then its best to contact the customer support.call, (248) 643-7222,
Monday through Friday,
between 9:00am and 5:00pm (EST)
and ask for Customer Service.
If you find that this answer helped you in any way, please "Accept" my solution in the premium you posted at
http://www.fixya.com/support/t624973-rainbow_e2_aquamate
I would be most grateful for your show of appreciation. Thanks in advance and good luck!
Posted on May 27, 2008
Agent Don
  • 310 Answers
SOURCE: Rainbow Aquamate 2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=620181
Rainbow Aqua mate 2 (by 3 users)
Posted by nicks mom on May 24, 2008
I cannot get water to come out of the water basin in order to shampoo. It is all connected correctlyXThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
2 Other Users Have the Same Problem Comment by deucedown, posted on May 26, 2008 Same problem here, I have only used the shampooer twice and water will not come out of the basin. I need to shampoo my carpets today and this is very discouraging. Somebody please help. I hooked it up and followed the directions. Comment by Angela31, posted on May 26, 2008 We are having the same problem. Everything is connected and no water is coming out. We have only used our Aqua mate 3 other times. Please help. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum / Aqua Mate. It has been a long time since I have operated a Rainbow Aqua Mate so I suggest that The best solution to operate the Rainbow Aqua Mate is to contact the Rainbow Tech Support line listed below or to contact your local vacuum cleaner dealer and have them send out a Rainbow Aqua Mate owner’s manual so that you can operate the unit successfully. By listening to the 3 questions listed above the actual water basin I believe is the recovery water tank to be emptied when full and I believe that there is a separately bottle or tank that the solution goes in order to dispense the water.
If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
  • 61 Answers
SOURCE: Where is the reset button in the e series Rainbow vacum cleaner?
Wait 12 hours empty unit and restart.
Posted on Apr 15, 2009
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 aquamate
Hello ,
U r missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box.
May 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer will not work on my e2 Rainbow. Help!
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
Thank you,
Ralph
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
May 25, 2009 | Rainbow 75th Anniversary Canister Vacuum
Instuctions on how to use them together
youhook up the shampooer the same way you would hook up the vacuum head. you can put jut a little bit of water in the basin and it basically works like the vacuum except it dispenses cleaner and water when you posh the button in on the handle.
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
How do you use the shampooer,
http://www.devicemanuals.com/sitemap.php YOU SHOULD BE ABLE TO FIND YOUR MANUAL HERE.OTHERWISE CONTACT ME & I'LL FIND YOU ONE.
Nov 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Aquamate 2
OK
Go Ahead. Use Us.
May 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
i have never used my rainbow shampooer and have had it 2 or 3 years it is not working it will **** up water but will not spray water or shampoo what do i do?
Feb 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
131 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
