Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
Usb connection???? i cannot connect the two usb ports on the front pannel becuase i dont know how to connect the wires
  • 114 Answers
Check this manual here ... it should give you how to get the connections done.
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5SD2-X/E2026_P5SD2-X.pdf
Posted on May 12, 2009
Front pannel usb connection for Motherboard (945GZM775SE)
Ok, what about the front panel usb connection??
If they don't work, you can always plug in a usb adapter into one that does work to get more usb ports.
May 16, 2012 | Biostar 945GZ-SE Micro Socket 775...
I had to clean my computer of dust and in doing so i un hooked all the wires and dont know where most of them go
YEAH! those are always fun,
you cant put a plug where it does not belong.
for internal wires, make sure the one attached to HD is plugged into the port with "PRI" written next to it, the rest will fit where they belong. if your reconnecting front pannel wires see the manual, you can download one from the manfacture.
any specific device on the inside?
for external wires (video, sound, keyboard) they should be color coded. the keyboard will go into the round purple port (unless its USB then just plug it into a USB port). the Mouse will go into a round Green port (again same thing with the USB). the monitor will only plug into the port that it will fit into. speakers tend to favore the light green 1/8th inch barrel jack, though i have seen some use the black one. mic is almost always the purple 1/8th inch barrel jack. (1/8th inch barrel jack is the same used for a MP3 player to connect to head phones)
the easiest way to find the speaker is to play some music then play pick a hole till speakers play sound.
Jun 10, 2010 | Computers & Internet
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
Find the correct connections on motherboard for usb ports
frist you have some port of usb on front pannel of cpu . connect the wire of usb . u can plug the usb card from on board pci slot then you need to enable your usb in bios
Apr 10, 2010 | EliteGroup K7S5A Pro Motherboard
I have pront panel audio and usb port but am not able to connect the pin can you please explain me the pin diagram to connect my front pannel usb and audio
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Aug 31, 2009 | Computers & Internet
Usb front panel connection
it depends on weither the case and the motherboard are the same usb connection . make sure that there both usb 2.0 or 1.1 not one or the other as the connections or not compatible .
May 01, 2009 | ASUS P4SGX-MX Motherboard
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
I dont know how to put usb connections
You can connect easily your pen drives, data cable etc. on your PC's USB ports. But what are you trying to connect on your PC. I think you don't find that where these connection will show? So, I tell you, after connecting to your PC's ports you can see them in "My Computer".
Feb 22, 2008 | Computers & Internet
USB
The USB ports on the front panel allow convenience for devices which you might connect and disconnect from time to time (like portable media card readers for example, or USB-camera cables) so you don't have to reach to the back of your case. If you are going to use the front panel USB ports, make sure they are connected to the motherboard inside if you are not using a store-bought computer.
Let me know if that answers your question.
Jan 11, 2008 | Zerus Intel Desktop Board D815EEA...
Flash Disk goes bad
Did you assemble the board yourself into the case? check to make sure your front panel USB connections are installed onto your motherboard in the correct order. Refer to your Motherboard Manual.If they are not, they can fry your usb devices rendering them inoperable on your pc or others. I have seen this before because of improper installation of front pannel USB connections. Good Luck
Apr 09, 2007 | Intel D915GUX Motherboard
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
143 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
