Question about Craftsman Garden
I need to put on a rear transmisson belt and I need a diagram
  • 41 Answers
Go to local sears ,they sould be able to get that for you.
Posted on May 12, 2009
Need traction drive belt path diagram and any helpful hints for installation. Old belt broke
look under mower where you put your feet
there may be a diagram there
if not usually one side of the belt is straight from rear to engine
the other side will go around the pulleys
Oct 10, 2015 | Garden
Need diagramof ground drive belt asembly
I just put a new one on mine. Your owner's manual has a diagram. Should be a diagram on the deck close to right rear wheel.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Manuel for a cubcadet 1525 modle how to put the belt on
There should be a diagram on the mower deck. The deck should be on the front hooks and have the rear pins engaged. Follow the diagram to install the belt. It may help to tie it in place with twine as you go. The last pulley to slip the belt over is the one on extreme left. You will need a 3/8" socket driver to slip into the square hole. Pull that back to extend the spring until there is enough slack to slide the belt over the last pulley.
BE CAREFUL!!!!!
Jun 17, 2014 | Cub Cadet Street Sign- tractor lawn riding...
I cant find were the transmission control solenoid is located at and need to replace it
what kind of transmisson is this 4t40or 4t60 or 4t65 or 4L60 ..well most general motor solenoids are located on the the transmisson valve body . which means on a rear wheel drive the transmisson pan needs to be remove to gain access to the valve body . On a front wheel drive the valve body is located under the side cover on the transmisson . Now if i remember rigth there are 3 or 4 control solnoids . 1-2 shift 2-3 shift and a Tcc solnoid . you need to know which one to replace and what location are they on the valve body
Mar 06, 2011 | Chevrolet Impala Cars & Trucks
How do i remove and replace the universal joints
should have 4 7/16 bolts holding the saddles on the rear of the drive shalft . you need to mark the drive shaft in the rear on the shalft and on the pinnon saddle (this ensures the shalft is put back in the same position it was taken off ) remove the bolts and pull the shalt out of the rear transmisson tail shaft . (some transmisson fluid may leak out of the tail shaft). Ok you may need a torach to remove the u joints being the OEM or put in with a sealed plastic in the cups . they need to be heated to remove this plastic so the cups can be pressed out . Or if they have been replace before there with be little clips on the inside of the cup that will need to be taken off. you will then need a vise or a way to press each cap out of the drive shalft . then the new caps will need to be pressed in . becareful not to drop any of the needle bearings out of the new caps or have them drop inside of the cap . if this happens you will not beable to press them in all the way
Mar 06, 2011 | 1998 Chevrolet Suburban
Clunking when i take off
sounds like a broken transmission mount, get a pry bar and stick it over the transmisson crossmember but under the transmisson and try to pry the transmisson upward, if it moves up and down replace the transmisson mount, if this isnt the problem my next guess would be the driveshaft u-joints, grab the driveshaft near the rear end and turn it back and forth to check for excessive play
Jan 14, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Tillers rotate put in gear wont move was moving just stopped is their a belt or chain in gear box or transmisson
Hi pat,
Yes, there are two chains in the tranny. If the wheels spin freely but don't engage, the smaller chain is broken.
If the wheels don't move, in gear or not, the smaller chain is broken and wrapped around the gears.
It's a bit of a chore to get to....
Mike
Apr 30, 2010 | Craftsman Rear Mount Tiller
I need to replace drive belt, how do i do it? its a craftsman model 135202, 5 horsepower rear tines.
From my searching the model tiller you have is #917.295352.
Go to www.searspartsdirect.com. You can put in the model number and it will show different areas for parts. The owner's manual is part # 152999 and the belt is # 9180R. The belt guard comes off you replace the belt and put the guard back on. If you need to take pictures or draw some diagrams to keep things straight.
Good day.
Oct 12, 2009 | Craftsman Garden
Serpentine belt broke
yes go to the auto zone web page or store and they can give you it for free
Aug 28, 2009 | 2001 Mercury Sable
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
