Question about Epson Stylus Pro 7600 InkJet Printer
Lines in print?
Hi there we have one of the epson stylus 7600 printers and whenever were printing anything on paper it has lines running threw the image? can you advise please we have drained and cleaned all the nozels is it something to do with how were printing.
You've probably done this but sometimes the obvious things are overlooked.
When I tried to print with the high speed option selected at anything below 720 dpi I would get lines across my print that resembled scanlines from old TVs. Adjusting the print settings cleared the problem right up. Of course the print times are a bit longer as a result.
Posted on Aug 22, 2009
    Scholar:
  • 50 Answers
It could be that the module unit of the 7600 needs to be replaced. If you don't want to pay for that, you could try cleaning off the wiper blade in the cleaning unit. You can kind of reach that from through the front door, but it is better to remove the side panel. The wiper blade will get ink built up on it, causing it not to clean well.
Also, when doing a cleaning, run it about eight times. After each cleaning, run a nozzle check. This causes the 7600 to do a more thorough cleaning job.
Posted on Jul 16, 2009
I have Epson stylus TX121 printer but whenever i m using to print out photo, photo comes in orange and red color, pls help me ....
Hi
When switching from printing on standard paper to photo paper, you need the change the paper and picture quality settings in Printing Preferences.
Start > (Control Panel) Printer(s) > right click on the Epson TX121 printer icon > Printing Preferences > Main > tick Photo or Best Photo > under Paper Options/Type select the closest match to the type of Photo Paper you are using (see photo paper packet for guidance) > Apply > OK.
Use the same procedure to switch back to standard paper settings to print on normal paper again.
I hope this helps
Aug 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a Epson Stylus Pro 7600. How can air get in the lines?
The only reason I know is by allowing the cartridge to completely run out of ink. That is why you cannot print in black only when a colour has expired. The printer does not only use the black cartridge it uses a bit from each cartridge to ensure the nozzles stay clean.
Jan 25, 2011 | Epson Stylus Pro 7600 InkJet Printer
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 - Oversize Printing
Select the proper page size in the page setup dialogue box and again in the various print dialogue box sub menus. Also make sure your printer is selected and you are using the correct drivers.
If all of these things are in place you should get a long list of paper types in the pull down menu when you attempt to print.
May 11, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson 7600pro air in ink line
You can try an Initial Fill of your ink carts. It is the next level after attempting to clean the heads. However, if this only temporarily fixes your problem, you could have a leak in the supply tubes, or the head could have failed.
Turn the epson off. Hold down the buttons [Paper Feed δ]+[Paper Feed ∇]+[Cut/Eject] and turn on the printer. This will take you into a hidden service menu. Hit the [Paper Feed ∇] button until you get to "Cleaning" then hit the [Select] button to enter that submenu. Hit the [Paper Feed ∇] again until you see "Init Fill", and then hit the [enter] button. The display will say "charging". Just wait until it is done, then turn the printer off and back on.
If you do not have enough ink in the in the carts you will be prompted to replace them. The same goes for the maintenance tank. Make sure you put the ink lever back in the lock position if you change the carts. (It will not give you an error about the ink lever being down, it just won't do anything.)
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson DX8450 not printing
are you using leopard os x? when you said you loaded the driver for the printer, did you use the disk that came with the printer?
Apr 03, 2008 | Epson Stylus DX4850 All-In-One InkJet...
Epson Stylus Pro 7600 InkJet Printer Logo
340 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
