Question about Motorola Mobility MoroKRZR K1m Cellular Phone
Battery doesn't last a day
After charging the battery shows 4 bars but after one or two conversations it goes down to 2 bars and one more conversation will kill the battery.  bought a new battery and charged it over 12 hours per instructions.  It only shows 3 bars and went dead on first conversation.  Is this really a battery problem or a problem with the phone?
  • 1 more comment
  • Del Holford May 12, 2009
    This was a new OEM battery.  After 12 hours charging it only showed 3 bars and went out after 1 conversation.  The original battery shows four bars and lasts about 3/4 of the day.
  • Ignacio Corella May 11, 2010
    Well, no clue over here, sorry I couldn't help.
    Have you checked with another battery?
  • 5 Answers
The new battery was missing a little filler piece from the original.  We crafted one which snugged the battery in the holder.  The tolerances are quite tight and the battery needs to be snug.
Posted on May 13, 2009
I bought new battery for my phone. Does it need to be charged with charger for 24 hrs.?
Minimum 15 min. With short conversations(2 to 4 min) keep on charger. Full charge in a 24hr period. Have a nice day.
Apr 19, 2016 | Cell Phones
My Whizzer motor bike will fire, but wont turn over and start
If you battery had a standard reading of 11.5 volts that drops down to .5 volts when you put load on the battery, your battery has gone bad. A healthy battery will give you a static reading of around 12.6 volts, and that will drop to about 12 volts when you're starting the bike. Conversely, when the bike is running, you should see 13.5-14.5 volts across the battery terminals. That shows that the alternator is charging and that the battery is good.
I have a vehicle with a battery going south. I have a static voltage of 12.16 volts, and I only get about 13.2 volts across the terminal when the car is running and the alternator is charging the battery. Soon, it will be time to change out the battery.
Hope this helps!
Mar 25, 2012 | Motorcycles
Phone keeps cutting out in middle of conversation
You need to ensure that the batteries are fully charged. On the handset while talking, the phone should show how much battery charge is left.
The other thing to check is how far are you from the phone base. For example if your base is on the first floor and you are on the third floor using the handset, then you might loose the signal clarity and eventually loose the connection to the base. To ensure that you are getting enough signal on all the floor, you can purchase a range externder from the manufacturer of your phone.
Dec 17, 2011 | Uniden DECT 6.0 Cordless Phone
IM´s doesn´t work... I was able to write them normally, but when I pressed "send" it showed that the message was waiting - and I know that my friend WAS online. The problem appeared in the middle...
How to clean Cache
1. Go to tools on the menu bar in your web broswer
2. Click on Options.
3. Click on Delete Key.
4. Uncheck everything accept for Temperary Internet Files.
5. Click on Delete Button and click on delete.
This is the number one reason why web pages won't load.
Dec 06, 2009 | Skype IM
Lost dial tone
is your unit is new?or your battery is new?if not,then it is probably your battery is weak.you cant say that a battery is GOOD if it still accepting a charge when you are going to charge...let me say that even if a power is stored on it ,you still can't say that it is still good.Becoz when a battery is weak,its current or ampere will become lower than the given specification when it was new.Thus,when a current is low,a batery can no longer supply the exact needs of the unit during the time of conversation,and thats the reason why it will shut down in just almost a minute of conversation even you know that it was fully charged .
Oct 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
My 2n tractor only puts out 3-4 charging. The
The 12 v conversion is the way to go. 6 v is a pain. It's getting harder and harder to get parts, and running off of battery power leaves a lot to be desired, especially if you've ever had to haul a dead battery back to the barn. I had a Farmall model "B", 1947, 6 volts. 12 volts was like a whole different tractor. Just my humble opinion!
Best regards, --W/D--
Aug 18, 2009 | Ford 2n, 9n, 8n Tractor Left Taillight...
I was just on the phone and finished my conversation and out of nowhere it powered off. I went to reboot it and the loading bar goes all the way up and the screen goes black. It keeps repeating this over...
i was texting and my nokia surge just turned completely off.it has no damage to it..i tried charging it but it wont even turn on or show that its even charging i dont know whats wrong with it n i dont have a warranty...
Sep 23, 2008 | Cell Phones
Casio Triple Sensor Pathfinder PRG60-1AV
Like anon129 I had the same problem. Those "outdoor" functions need more battery power than just telling the time and the stopwatch do. When the rechargeable lithium battery gets old and tired - which they apparently sometimes do for no very good reason - it can't provide enough power when required to, so it goes into recovery mode. It's very annoying but if your battery level indicator is already showing H the only solution is to replace the battery.
My second battery seems to be lasting better, but I'm not leaving it charging in the sun for ages this time, as I think it overheats it when the battery is full. I'm also not using the outdoor features as much, and the light hardly at all.
Apr 13, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
Motorola Mobility MoroKRZR K1m Cellular Phone Logo
97 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
