Question about Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator
Hi i have side by side refrigerator frigidaire model phsc239dsb3 replace power main board runs ok but showing e f code on the display e on the freezer side and f on the food side. any idia how to get real of the ef code please jeff
  • Anonymous Mar 17, 2014
    codes are showing 5Y and EF
Bought a new one.thanks
Posted on May 13, 2009
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
Why does my FRSH6KR5JWO side by side temp. control flash 4 ?
Hi Friend, this is Z. I appreciate your post!
If an error code 4 is flashing on your Frigidaire refrigerator (FRSH6KR5JW0), it generally means that your refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly which typically causes the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about ten minutes. However, since you have already done this, at this time it is best to reach out to a professional to check the wiring between the damper and Main Control Board. Depending on the results, either the damper or Main Control Board may possibly need replacing. Best regards!
Aug 12, 2014 | Frigidaire Refrigerators
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Frs6lc8fs3. freezer nor frige is working and flashes a #4 on the display.
On your model the digital controls are the main controls called a Genesis Control. It has 2 part numbers for the same part. 241739701 or 1196804 Digital Control
When compressor and fans are not running that control is the most likely reason. Reading #4 may be a failure code but looking over the wiring diagram there is really not much more that could be the reason for a fault failure code of that board. Shows that you still have voltage to the board but because everything is controlled from there like measuring the freezer and refrigerator temperatures, defrost and switching the compressor and fans off and on I believe your problem is there. Sorry about the troubles, Sea Breeze
Oct 15, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator Logo
434 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
