Question about kawasaki Full Suspension Mountain Bike Men
Hi i have a kawasaki kx 125 1991 motocross bike,my problem is when running it will not go out of gear i have just fitted a clutch cable but its still the same,could it be i need new sprigs/plats or just the houing ,
  • stephane richard May 11, 2010
    you mean it can not get out of gear or it wanna move forward even the clutch is pull....waiting reply
  • 46 Answers
It feel like the actuation of you're clutch lever does not disengage you're clutch plate ...i will think that you're clutch actuation arm ( the one the clutch cable get in... is not engage at the right place or the arm is not on the right spline)...spring and plate only is an issue when the clutch is sliping....
Posted on Sep 14, 2009
1991 Kawasaki KX 125 clutch hard to disengage
Hi, Chris and the usual suspects are:
1. Clutch cable bent, kinked, pinched, rusted or needs lubrication.
2. Hydraulic clutch hose collapsed or pinched.
3. Improper clutch adjustment.
4. Clutch plates rusted.
5. Pressure plate or springs to heavy for service.
6. Damaged clutch shell.
7. Damaged, bent, or stuck push rod assembly.
8. Faulty worm gear mechanism.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KX125 Clutch doesn disengage
clutch wont disengage
Kawasaki KX125 Service Manual
OEM Parts for Kawasaki
1991 Kawasaki KX125 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 12, 2014 | kawasaki KX 125 Motorcycles
2003 Kawasaki KX 250 hard to pull in the clutch lever
Hi, Anonymous and the usual suspects are:
very hard clutch pull on 99 kx125
hard clutch pull on 99 kx 250
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX-125-KX250-Service-Manual-2003-2004-2005-2006-2007-2008.pdf
2003 Kawasaki KX250 Owner Manual
Jan 12, 2014 | 2003 kawasaki KX 250
1992 Kawasaki GT 750 cable clutch replacement
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
How To Change Motorcycle Clutch Cable Transworld Motocross
Kawasaki KZ 750 speedometer and clutch cable replacement
Kawasaki Motorcycle Service Manuals
http://mybikemanuals.com/kawasaki
Nov 24, 2013 | 1992 kawasaki GT 750
2006 KAWASAKI KX 250 F HOW TO REPLACE THE OIL PUMP IDLER GEAR
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Part 11 Assembling motocross Bike Oil Pump and Strainer YZ250F example
How To KX250F Top Bottom Engine Rebuild Part 1 of 3
http://www.mx-sport.ru/files/servicemanual-KX250f-06.pdf
2006 Kawasaki KX250F Owner Manual
May 24, 2012 | 2006 kawasaki KX 250 F
1991 Kawasaki KX 250 how to replace the clutch
Hi, Firefight685 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
04 kx250 clutch installation help
Kawasaki kx250 clutch rebuild
https://www.scribd.com/doc/121008272/KX125-KX250-94-98-Service-Manual
1991 Kawasaki KX250 Owner Manual
May 18, 2011 | kawasaki KX 250 Motorcycles
2006 Kawasaki KX 450 F how to re-gear the transmission ratio
Hi, Active135 for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day. Adjusting Your Drive Ratio Changing Your Sprockets for Maximum Performance
https://www.motosport.com/blog/the-ultimate-dirt-bike-gearing-guide
http://www.mx-sport.ru/files/servicemanualKX450f-06.pdf
Download Manual 2006 Kawasaki KX450F Owner Manual
Feb 19, 2018 | 2006 kawasaki KX 450 F
2006 Kawasaki KX 250 F bike dies when the clutch lever is pulled in
Hi, Jasonstein the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
Bike died while pulling clutch lever KawiForums Kawasaki Motorcycle Forums
http://www.kawasakimotorcycle.org/forum/kawasaki-motocross-offroad/69807-kx-250-stalls-when-put-into-gear.html
Apr 18, 2010 | 2006 kawasaki KX 250 F
Kx 125, wont select gear
Chris make sure that you have put the brass washer back on the drain plug the tolerances of the 03's were so tight that the drain plug going into the case even that tiny extra amount will affect shifting and clutch performance Good Luck
Oct 20, 2009 | 2003 kawasaki KX 125
Italjet 80 motocross clutch problem
Push start the bike and shift gears when coming to a stop if the bike does not stay running - yes it is the clutch system
Oct 15, 2009 | 2000 Italjet Grifon 900
kawasaki Full Suspension Mountain Bike Men Logo
312 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
