Question about Fisher and Paykel GWL11 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
The washer will actually add water from the right hand side fill during the spin cycle. This water is then sprayed around inside the cabinet and leaks out onto the floor. This never happened prior the unit having some issues during the spin cycle that seemed to be repaired by unplugging the machine for a few minutes to eliminate the annoying beeping and failure to finish the cycle. It does run through the complete cycle now but leaves a mess on the floor.
  • GWL11 owner May 13, 2008
    I'm having the same problem.
  • Anonymous Mar 24, 2014
    when the washer starts to drain for the spin cycle water comes out from under the unit
  • 58 Answers
Diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Posted on Oct 31, 2007
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
My Fisher Paykel gw612 leaking water from underneath during the spin cycle. I can't see any leaks underneath and the hoses and side of the machine stay dry. Also when it is filling it makes a slight...
my quess its a big job, check to see if there are any leaks from the motor, you may have faulty seals, also check the water seals around the electroncis board, once water gets into the motor it becomes a big job. i need more info.
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
During spin cycle water on floor from outside
May 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
No water inputted in rinse cycle
Turn off the cold water valve supply to the washer and unscrew that hose off the back of the machine. Take the screen out from inside the washer where the hose was screwed onto. Clean out the screen and re-insert it. Re-attach hose, turn valve back on. Presto, better water fill rate.
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
4 year old Fisher Pakel washing machine
Hi and welcome to FixYa!
Some things to check- Start with the water pump underneath the machine in the right-front of the unit. Look for signs of rust or leakage, that would be the most likely cause. Also check the operation of the diverter valve, inspect it to make sure there is not something like a lint ball or small object caught in the flapper; this can allow water to seep out of the diverter when it is supposed to be sealed in the spin or drain cycles and this seepage will get on the tub's rim as it spins and cause a leak on the floor. This kind of leak will cause water to appear as if it is leaking between the top and the cabinet.
Word of caution- the water pump is electric, and if you allow this leaking to continue, it can actually short out boh the water pump as well as the machine control.
If afer you solve the issue, if you find that I have accurately described the problem, a FIXYA rating is greatly appreciated. Thanks!
Feb 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
507 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
