Hitachi 53FDX01B 53" Rear Projection Television Logo
Betty-Jo Osborne Posted on Dec 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No Sound on my Hitachi 53FDX01B 53" Rear Projection Television
No sound, but everything else works great. Not sure what to do. PLEASE HELP!! We tried hooking up the speakers to a stereo speaker but still didn't work. Checked the back of tv to see if there were any wires not connected but everything looks good, just a little dusty.
Steven Brandon
Level 3:
Master:
  • Master 462 Answers
  • Posted on Dec 10, 2013
Steven Brandon
Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117674
Points
1705
This is a board level problem. If interested I can help you find the problem. You will either have to do some soldering or replace the board.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5 Related Answers
Anonymous
  • 647 Answers
  • Posted on Oct 25, 2009
SOURCE: Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Testimonial: "Thanks."
atelier mj
atelier mj
  • 70 Answers
  • Posted on Apr 22, 2010
SOURCE: 52 Hitachi rear projection T.V. (model #, 53FDX01B)
look for EP98, Q655 and D756.
Anonymous
  • Posted on May 10, 2010
SOURCE: Hitachi Rear Projection TV - C4678FS - No Sound
i am having the same problem with my hitachi.. if you find anything out plz let me kno
Anonymous
  • 96 Answers
  • Posted on Sep 13, 2010
SOURCE: I am about to have AT&T U-Verse installed. I
It should say HDTV on the bottom left corner of the tv if it is HD ready.
Anonymous
  • 608 Answers
  • Posted on Dec 18, 2010
SOURCE: Hitachi 53FDX20B 53 in. Rear Projection Television
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
My hitachi 53fdxo1b has sound but no pic
Replace the light, check for blown or poped capacitors and resistors on the circuit board. Pliz vote if it works, good luck.
I have a hitachi ultravision 53in fdx01b im experiencing a blue doublevision please help.......
sounds like the convergence circuit has decided to quit working..  hitachi uses convergence output i.c.'s for this in the circuit.  one is probably bad.  suggest replacing both though..
Hitachi HD 53" digital projection tv
Good Day; brannie1;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Hitachi 53FDX01b rear proj tv
Good Day;
If you have digital cable box upgrade to HD box or Sat. box.
Rear projection tv has sound but no picture for the first hour
hello
The problem is most likely the the video processor module
bad (surface mount caps.) app. 8 to 10 of them.
If you are good you can replace them.
if not replace the module.
guy9
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
